My Catch Pan - Easy to build
Ok, i know a lot of people have been waiting till last minute to deal with the catch pan for NHRA. This includes me. Today I finally decided to make one.
I started with a piece of sheet aluminum, folded a diagonal for stability and center puddling. Then, I cut 2" nothes in the corners, then bent up the sides, riveted and sealed the corners. I made Z brackets to attach to the frame. In the front, it bolts to where the dirt shield would go. In the back, i self tapped it to the subframe.
When the car is jacked up, the lip hits the lower control arms, when its on the ground, it has about 1.5-2" of clearance (plenty to allow for wheel hop). Here are the pics.
Also, i have 3.5" of ground clearance still.
1-this year its required for all sportsman races. well, this or a blanket, but since there is no blanket for hondas, not much else you can do.
2-no SFI required (as of now)
good to know. I thought I saw in an update that the pans werent gonna be required till next season due to the limited supply of manufacturers actually producing them right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Are they requiring absorbent lining inside as well?</TD></TR></TABLE>
tha would be some new news if it is the rule book doesnt say it does.
yeah, you serious? i had no problems this weekend at tech. no where in the rules does it say anything about lining. nothing. You'd hear quite a bitching from me if they tried to say it had to have **** not mentioned anywhere outside of their brain.
