CEL /ECU Light is solid
Old Apr 20, 2007 | 11:34 AM
PnkRokCountryboy's Avatar
Default CEL /ECU Light is solid
I have a 1990 CRX Si, and when I turn the car to the "on" position, I have a CEL and the light on my ECU is solid. Everyone I ask says that my ECU is bad, but I got another PM6 out of a running CRX Si, and plugged it in. The light on the new ECU is still solid. I'm not getting any spark when I try to crank it over, either.
Any ideas? Has this happened to anyone before?
Me and all my friends are at a loss, so any suggestions would be amazing.
Thanks a lot.
Old Apr 20, 2007 | 11:51 AM
jchung's Avatar
Default Re: CEL /ECU Light is solid (PnkRokCountryboy)
i'm not sure if you have to when you change your ecu, but did you reset your ecu by pulling the battery/10 fuse?
Old Apr 20, 2007 | 03:22 PM
Default Re: CEL /ECU Light is solid (jchung)
no, but I'll try it.
right now I'm checking my wiring harness for any frays or breaks.
Anyone else have any ideas??
Old Apr 21, 2007 | 05:22 AM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jchung &raquo;</TD></TR><TR><TD CLASS="quote">i'm not sure if you have to when you change your ecu, but did you reset your ecu by pulling the battery/10 fuse?</TD></TR></TABLE>
you dont need to worry about that. Unplugging the ECU and plugging it back in works the same as pulling the battery/fuse. And you are already doing that.
I would go with what you are already going to do by checking the wires
Old Apr 21, 2007 | 05:46 AM
Bejita's Avatar
A solid light on your ECU means the ECU is bad.
Old Apr 21, 2007 | 05:59 AM
nexgen91's Avatar
Default Re: (Bejita)
if your ecu is chipped, it could be a bad ROM had that happen to me.
Old Apr 21, 2007 | 02:04 PM
Default Re: (nexgen91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">A solid light on your ECU means the ECU is bad.</TD></TR></TABLE>
The ECU is fine, it was from a running car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexgen91 &raquo;</TD></TR><TR><TD CLASS="quote">if your ecu is chipped, it could be a bad ROM had that happen to me.</TD></TR></TABLE>
Its not chipped, just a stock PM6
So far I've found a couple broken wires on the harness, so I'm connecting those back.
Anything else anyone can think of?
SCR ZC-T's Avatar
check your main relay.
when you turn the key to the on position the check engine light comes, you'll hear the main relay click ( turn on) which is activating the fuel pump in order to pressurize the fuel system. it'll do this for like 5 seconds then the check engine light turns off and so does the main relay. if the check engine light turns right back on or just stays on its usually the main relay. it is locate behind above the hood release lever. open it up look for cracked solder joints. if you find any just touch 'em up but sometimes you just gotta get a new or good used relay.
da9blk1
Jul 19, 2010 08:04 PM
egbaby
Feb 24, 2008 12:30 AM
sirhavok
May 30, 2007 06:45 PM
tallguy
Dec 1, 2005 08:25 AM
CleanLIttleLude
Jun 13, 2003 12:09 PM
