Idle question
Old Apr 20, 2007 | 04:09 AM
BoostedRedline's Avatar
Default Idle question
sorry if this has been posted before. i just did a swap from a d15b8 to a d16y8. i started the car up lastnight and the idle fluxuates up and down from 200rpm to 2500rpm. i hvae been told it is a vacuum leak, but i have blockedoff every line i can find. someone also told me it could be because i dont have any coolant in it(the cross tube on the back of the motor is leaking at the water pump, so i didnt put coolan in it). can someone help?
Old Apr 20, 2007 | 05:46 AM
kin413's Avatar
Default Re: Idle question (BoostedRedline)
yeah just replace it
it should be fine..
Old Apr 20, 2007 | 06:55 AM
Boostedb20EH2's Avatar
Default Re: Idle question (kin413)
Replace what?
Its either a vaccum leak. Your fitv. Or your iacv.
I put money on the fitv.
Old Apr 20, 2007 | 07:29 AM
Lmgrcivic's Avatar
Default Re: Idle question (Boostedb20EH2)
also make sure all your grounds are good. no leaks in vaccum, no air pockets in the coolant lines.
Old Apr 20, 2007 | 07:55 AM
someone help me out on what an fitv is? laso i was have no coolant whatsoever in the car
Old Apr 20, 2007 | 08:00 AM
92ehatch's Avatar
Default Re: (BoostedRedline)
d16y8 doesnt have an FITV its obd2
check the iacv
its on the back of the intake manifold. take off 2 12mm bolts and clean the screen out with carb cleaner.
bleed the coolan properly as well.
do you have any cel?
edit....put ****** coolant in it, jesus, i just read you didnt put any in it
Old Apr 20, 2007 | 08:44 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedRedline &raquo;</TD></TR><TR><TD CLASS="quote">someone help me out on what an fitv is? laso i was have no coolant whatsoever in the car</TD></TR></TABLE>
Why is it that you dont have coolant?
Old Apr 20, 2007 | 08:48 AM
shatchi's Avatar
pressure test it.
Old Apr 20, 2007 | 08:50 AM
John M's Avatar
Default Re: (shatchi)
Wtf no coolent?
Old Apr 20, 2007 | 11:34 AM
i just put the motor in last night. and we just started it to see if it would start. the water line on the back of the motor that connects the wtaer pump to the water outlet is busted so the coolant just drains right out. i know it needs coolant, but i didnt think no coolant could cause the idle being fucked up. i got the new water line and im putting it on tonight and i will see how it goes
Old Apr 20, 2007 | 12:08 PM
97Ej6mike's Avatar
IACv IACv IACv
Its like people always have problems with the IACV, lol.
Make sure your IAC is hooked up correctly, and functioning as well.
The FITv Really doenst make the motor lope, I have a friend who Bypassed his altogather, and it runs perfectly normal.
Old Apr 20, 2007 | 12:52 PM
is the idle air control valve located on the back side of the intake manifold? since i went from obd1 to obd2 i noticed there is some connectors and vacuum lines that i have no place to hook up
Old Apr 20, 2007 | 12:58 PM
phondataz's Avatar
why would you ever run a motor even for one minute with no coolant??
Old Apr 20, 2007 | 01:19 PM
97Ej6mike's Avatar
Default Re: (phondataz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phondataz &raquo;</TD></TR><TR><TD CLASS="quote">why would you ever run a motor even for one minute with no coolant??</TD></TR></TABLE>
***** and giggles?
Old Apr 20, 2007 | 01:22 PM
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">IACv IACv IACv
The FITv Really doenst make the motor lope, I have a friend who Bypassed his altogather, and it runs perfectly normal.</TD></TR></TABLE>
Mine did.
AllThumbs
May 8, 2013 04:54 PM
vlude99
Feb 3, 2009 04:39 PM
lude98SH
Oct 29, 2006 03:17 PM
Silent_Destruct
May 24, 2006 02:10 PM
suspendedHatch
Jan 12, 2005 03:19 PM
