Purchasing a Type R motor, have a question
I figured i come ask you guys since il probably get the best answers from you's
Im going to purchase a type r motor from hmotorsonline, but not sure which spec to get. Is it worth it to get the 96-97 spec for 3999$? Or spend the extra 500$ and get the 98+ spec? Are their any major differences? Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">soo what happend to the JDM 4-1 header, bigger cams, and 4.7 final...yes it's worth it, which is why I just bought one from HMO
in the JDM motor everything is EXACTLY the same in all years apart from the process of machining the valve ports
1. he never mentioned anything about getting a header with the engine
2. there was no difference in cams in the B18C Spec-R engine anywhere except the US
3. he said "motor", not motor and gearbox
HTH
</TD></TR></TABLE>in the JDM motor everything is EXACTLY the same in all years apart from the process of machining the valve ports
HTH
if this organisation is NICE enough to supply a manifold with the motor, then you'll get the 98+ spec 4-1 single piece
if you get the 96-97 motor then it will come with the 4-2-1 two piece
both have a 2.5" collector, but the later manifold is all stainless and is designed to give more torque at lower revs
and sicones, he only asked what the differences were between the motors
Another vote for 98+
The 4.7 FD alone is about $350ish and then the header by itself is around the same for a nice one. Then you have the port stuff.
Also, the mileage thing would be another reason I'd go for the 98+
Chemi421
May 5, 2006 10:00 AM
HATCHingMN
May 24, 2005 09:14 AM
PS4SE-R
19
Jun 2, 2003 08:06 PM
