d15b wont start battery is good wont crank
Old Apr 19, 2007 | 10:46 PM
jimboek's Avatar
Default d15b wont start battery is good wont crank
when i try 2 crank it it wont start if i push start it it starts i dont kno a friend told me i need more ground wires to the negative battery or it could be my starter what u guys think
Old Apr 20, 2007 | 02:46 AM
NVMYSTI's Avatar
Default Re: d15b wont start battery is good wont crank (jimboek)
check all the connections on the starter to make sure they are all hooked up
Old Apr 20, 2007 | 03:09 AM
Eran's Avatar
HT White Ops
I'm betting on your starter. Your motor will start with the stock grounds, so your friend is an idiot for trying to tell you you need more of them.
Take your starter to Autozone and have them test it. It cost all of $0.00 ....
Old Apr 20, 2007 | 05:41 AM
kin413's Avatar
just buy a new starter that will solve the problem
Old Apr 20, 2007 | 06:14 AM
Bakeoff's Avatar
The ground thing is myth and truth... It's an enigma! Muahahahaha.
Anyway, I've had motors that after install wouldn't start. Turn the key and the dash lights would go dim. Turn it off and back on, try to start it, same thing. Adding a ground made it pop right over. They get corroded and don't conduct well over the years.
Is the starter making any noice when you turn it to start? A click? A loud click? Anything?
It could be as simple as the spade connector slipping off starter signal connector.
Don't waste your time replacing anything until you check that.
Old Apr 22, 2007 | 12:15 PM
jimboek's Avatar
dam still not working.... -_-
Old Apr 26, 2007 | 07:12 PM
91HBDX's Avatar
What turned out to be the problem my car is doing the exact same thing??
JJT211
Jun 22, 2014 08:33 PM
Daku99
Jan 1, 2013 09:08 AM
DriveSlowHomie
Jan 26, 2010 10:31 PM
lPat
Nov 3, 2007 08:19 AM
porkchop14
Sep 28, 2004 09:10 AM
