Flaring out the fenders and 1/4 panels
I want to run wider rims/tires on all 4 corners, mostly for show, dont flame
my question is what is a good way of flaring out the fenders, i only need about 1.1" extra, so the new rims fit and not rub, im not gonna do the work myself but would like to hear some ideas as to how to do this, weld new sheet metal and then shape it, bondo it smooth? THanks!
just roll the fender with a baseball bat.....
you just place the bat inbetween the tire and fender, and roll the car back and fourth while someone is holding the bat in place, you have to roll it back and fourth a few times to see progress, but alot cheaper than getting them professionally rolled.
He is wanting to add a flare to the fender like im guessing you can rivit a premade flare on and go back and cut the metal under the flare out.
its a CB7, 90-93 accord. And yes i want flared fenders, not just rolled, i need 1" extra added, but dont want it to look out of place, want it to look as oem as possible.
make some templates out of cardboard then get those fitting how u like, copy the patter onto sheet metal. hammer dolley. test, hammer some more, test, weld on fiberglass in. basically howd i would approach it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff »</TD></TR><TR><TD CLASS="quote">make some templates out of cardboard then get those fitting how u like, copy the patter onto sheet metal. hammer dolley. test, hammer some more, test, weld on fiberglass in. basically howd i would approach it</TD></TR></TABLE>
Check out vipstylecars.com
They have tons of rolling and pulling fender topics.
Only thing you have to become a member to search.
Awluiz
Feb 11, 2013 10:40 AM
Hella_Fresh
Mar 10, 2007 01:31 AM
