Rolling Rear Fenders on EG8 Sedan.
Just added new Rims and Tires, and coil overs. I lowered it, but it's not slammed. The tires are scrubbing on all the dips in the road, the fronts fine, but the rear is scrubbing. I don't want to raise it back up, because it looks great, I'd rather just Roll the fenders out, but I was looking at it, and the area is so small, I was wondering if you even CAN roll the fenders out? So, I'm just wondering if anyone knows if it's possible? Or should I just get some skinnier tires, I don't have stretched tires or anything. Just Basic bigger, nicer rims, and some fairly meaty tires.
Re: Rolling Rear Fenders on EG8 Sedan.
You can take a baseball bat and beat that **** out lol But if you wanna roll them go buy or rent a fender roller and do that **** the right way homes
Roll the fenders out? You don't roll fenders out. You roll fenders in (or under), or flare fenders out.
Buy a flaring tool. Use it. Sell it or keep it.
Location: Pensacola, FL and every Court House in Louisiana
Like said above you roll the lip, you pull or flair the fender out. I have used a base ball bat with the car jacked up enough to get the bat between fender and wheel. I have used this method several times and it worked great.
I honestly wouldn't want to do it myself without the proper tool for it that I know they make, I'd let someone else do it that has done it that way. But I don't want to mess it up. I get the idea on how to do it. It's just the method, and the tool. I know the difference between rolling out, and flaring out, and everything. I just left it in the open with the most basic term for doing it to your car, figured you'd have enough common sense to understand what I was saying. The rudeness was unnecessary. I'm new to any body work, suspension work, all that. I know about working on the motors, that's why I asked. But is there somewhere you can rent the proper tool for the job? Or can I just take it to an auto body shop and have them do it fairly fast?
i had a simmilar problem when my rear springs went out (before the ones i currently have) and are you sure you are hitting the fender and not the wheel well?
It's possible to roll the fenders flat/pull , but since your wheel hub is closer to the fender , you would have to take out the bolt that holds the bottom of your coilover to the lower control arm so that the fender roller could fit
msinsky14
04-16-2006 02:12 PM
