hate that dent on your car? there is hope
i saw this today..
dam if it really works then.. Amen
Dent Fix Equipment, manufacturers of high quality body shop products announces the addition of Dent Out Paintless Dent Removal Glue Puller kits to their line of Auto body tools. These easy to use, inexpensive Glue Puller Kits allow for simple, cost efficient removal of dents. More and more, light gauge sheet metal is being used in the construction of vehicles. You can actually dent many new cars by simply leaning against them. Door dings make you want to scream and they reduce the value of your car. Dent Out Glue puller kits allow the do-it-yourselfers, a professional option to expensive dent removal services. No need to access the underside of the panel. Each unique kit offers a tool for specific damage. With four kits available, they encompass all types of dent repair. Simply apply a bead of glue to the pulling nib and affix the nib to the lowest area of the dent. The tool slips over the threaded stud. A wing nut tool is threaded down pulling the metal up. Once the dent is pulled out, a couple of drops of release agent is applied to the glue and the pulling nib comes right off. Use only on OEM baked finishes. Will not damage factory finish.
T-HANDLE SET-Ideal for small to large dents on side panels.
CONE SET-Designed for dents smaller than 1 ½ inch in diameter. A great tool for hail damage.
CROSS-BAR SET-Ideal for small to medium damage on all panels.
PRO KIT-A Complete set of heavy duty dent pulling tools incorporates a glue gun, super bonding adhesives and release agent into a strong, blow molded plastic carrying case. Turn parking lot door dings, shopping cart dents, minor creases, hail stone damage, damage from golf *****, baseballs and stones, dents caused by objects shifting in the trunk into a profit center. The Pro kit offers two different adhesives allowing you to select for shallow dents and depressions or a high tack adhesive for deeper depression, higher ambient temperatures or higher humidity.PRO KIT includes: 1 Tripod, 1 Cross-Bar, 1 Cone, 10 T-Handles, 2 Wingnut Tools,5 small glue nibs, 5 large glue nibs, 10 sticks High Strength Glue, 10 sticks Regular Strength Glue, Glue gun, tap down tool.
LOL thats a really impressive site for a bussiness considering how the pics dont work... Your average small grocery cart ding in your door will cost $200-$300 at your local body shop, or so Ive been told.
