Help: Choosing CRX LCA's
I've seen a few posts saying to avoid different runs of Megan/Omni LCA's so im here to ask which brands i should go for. Need some opinions as to which brand is the best pick, i've heard Function 7 is good but i want to see what other people believe are the best LCA's.
Best LCA on the market is OEM HONDA! What is your purpose for new LCA? Just seems like a waste of money for something that does nothing for the performance of your car.
If you want to stiff suspension get some bushings put in. OEM is steel, aftermarket is typically alum which is not as stiff. As far as weight, I would ask what you are using the car for to reduce a few expensive pounds.
you want to loose weight then get the oem ones from the hf and sir thats what i did
https://honda-tech.com/zerothread?id=1956082
scroll down a bit there the ones i installed with my ksports and they are awesome
oem ftw
oem ftw
Biggmike92vx
10
Jun 3, 2007 09:06 PM
leadfoot78
Suspension & Brakes
17
Jan 5, 2005 05:34 PM
crx, honda, install, installing, lca, lcas, megan, opinion, performance, review, suspension, tech, tubular
