Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Does a SRI void the honda warranty???if not what does??
Old Apr 19, 2007 | 07:05 PM
redcivic06's Avatar
Default Does a SRI void the honda warranty???if not what does??
I was just asking because i have to take my ex to the dealer because of some transmission problems...so i just wanted to know if i should take off my SRI and put the stock one back on b4 i take it back to the dealer.
Old Apr 19, 2007 | 07:12 PM
Honder07si's Avatar
I think the dealership has to prove that what you did to your car (SRI) was in direct relation to what is wrong/being worked on... so you should be fine.
mr poo's Avatar
Default Re: Does a SRI void the honda warranty???if not what does?? (lilredcivic06)
if it's carb legal then theres no way in hell they shouldnt warranty your transmission. unless you did something obviously wrong, like cut a hole in your transmission to put the air filter in
Old Apr 19, 2007 | 07:18 PM
itz smokin's Avatar
Default Re: Does a SRI void the honda warranty???if not what does?? (mr poo)
here's one of the warrenties that honda does not cover:
"Any failure caused by modifying the vehicle, or installing accessories not authorized by Honda."
Old Apr 19, 2007 | 07:24 PM
redcivic06's Avatar
Default one more question....
and another question......can the dealer get any information from the car about high revs and imporper shifting...in other words abuse.....
Modified by lilredcivic06 at 9:13 PM 4/19/2007
Old Apr 19, 2007 | 07:27 PM
Honder07si's Avatar
ECU can tell anything pretty much i believe
Old Apr 19, 2007 | 07:28 PM
FBPSidan's Avatar
Default Re: one more question.... (lilredcivic06)
i think they can only get that if it throws a CEL but i could be wrong
Old Apr 19, 2007 | 07:48 PM
Kiwibird83's Avatar
Reigning GDD Queen
Honda's ECU systems are still plenty behind GM's, but on chevy vehichles you can scan back quite a ways with the tech 2 for over revs and high load situations to check for engine abuse from a client, hell it even takes snapshots and stores them to memory. Honda most likely has the same ability, just less playback memory/history.
I doubt the dealer will blame you for anything, unless of course you powershifted your tranny to hell and broke a blocker ring or something of the sorts. Since a SRI has no way of directly affecting a transmission they cant deny you a claim becuase of it.
Old Apr 20, 2007 | 10:50 PM
ley's Avatar
ley
If you install an intake without a water bypass valve, it voids the warranty.
ergot4
Honda CR-V & Element
May 6, 2021 09:41 AM
hondalion
Dec 5, 2012 08:19 PM
R_ACE1
10
Jul 18, 2009 03:34 PM
lovemydc5
Jun 15, 2007 12:26 PM
FyrFytr
Aug 6, 2002 01:09 PM
