Fixing a bashed in fender
Old Apr 19, 2007 | 03:44 PM
MasterGDP's Avatar
Default Fixing a bashed in fender
I hit a tree, long story short.. my fender is just bent in with a cut in it. Whats the best method on pulling the dent out? Any help is appreciated
Oh yeah, first thread in Paint/Body FTW
Old Apr 19, 2007 | 03:57 PM
Finest's Avatar
Default Re: Fixing a bashed in fender (MasterGDP)
Front fender? Just replace it with a used fender from the junkyard, then repaint to match.
First reply in Paint/Body, FTMFW!
Old Apr 19, 2007 | 03:59 PM
John M's Avatar
Default Re: Fixing a bashed in fender (Finest)
You could if it isnt to bad just take it iff and use a rubber hammer on the back. then thin layer of bondo of needed.
2nd reply in Paint and body FTW!
Old Apr 19, 2007 | 04:10 PM
Lucky-13's Avatar
Default Re: Fixing a bashed in fender (John M)
Yeah id just go with the rubber hammer and some bondo. Or the junkyard, either or it will fix it
3rd reply in P/B
ilsimsli's Avatar
fenders arent worth fixing just replace it there cheap
btw paint and body forum
Old Apr 19, 2007 | 04:35 PM
Single Cam Slam's Avatar
If you bondo you must strip the paint all the way off to bare metal 3" all the around where you are aplying the bondo. Bondo will not stick to paint.
Old Apr 19, 2007 | 04:39 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Would USC Icing or Metal Glaze be better than bondo? I seem to only hear bad things about bondo.
Old Apr 19, 2007 | 04:41 PM
Lucky-13's Avatar
Default Re: Fixing a bashed in fender (-NA-aLL-thE-wAy-)
Ive used bondo with success....only problem was I hit a mail box and the bondo cracked. Id be interested in trying another form of body filler though.....what is USC or Metal glaze??
Old Apr 19, 2007 | 04:46 PM
EFSS153
Default Re: Fixing a bashed in fender (YoUvegOtMaiL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoUvegOtMaiL &raquo;</TD></TR><TR><TD CLASS="quote">Ive used bondo with success....only problem was I hit a mail box and the bondo cracked. Id be interested in trying another form of body filler though.....what is USC or Metal glaze??</TD></TR></TABLE>
There is info in these two posts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]<u>Engine Bay "Icing" or "Filler" &raquo;</TD></TR><TR><TD CLASS="quote">USC ICING
Slappy: "I think that's what (Bryan) Pandahatch used.......Ive heard good things about that one."
OR
Link for Evercoat Metal Glaze:
http://www.evercoat.com/productDetail.aspx?pID=1
Pic for Evercoat Metal Glaze:
http://www.evercoat.com/imgs/p...e.jpg </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]PandaHatch on <u>Fillers/Bondo... &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT USE BONDO!!!!!
There is USC Icing and Evercoat Metal Glaze. Take your pick, they're essentially the same.
I did ALL my sanding by hand, except for the core support otherwise I used a DA, EVERY contour is and done, I feel when working with complex shapes, you can get a better feel with hand.</TD></TR></TABLE>
John M's Avatar
I have heard of the metal glaze but thought it was only to fill in light scratches in the metal. Like little gashes.
Old Apr 19, 2007 | 04:49 PM
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">I have heard of the metal glaze but thought it was only to fill in light scratches in the metal. Like little gashes.</TD></TR></TABLE>
Most people are using it on their engine bays to fill small spots (such as spot weld dimples) and seams. I haven't heard any compaints yet. My Paint/Body issue of Hot Rod Magaizine also recommends it. Peeps say it's easier to work with and easier to sand.
Old Apr 19, 2007 | 04:52 PM
John M's Avatar
I might try that im thinking about doing my bay also.
Old Apr 19, 2007 | 05:07 PM
SHG_Riley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilsimsli &raquo;</TD></TR><TR><TD CLASS="quote">fenders arent worth fixing just replace it there cheap
btw paint and body forum </TD></TR></TABLE>
x2, i replaced both my fenders recently, easy to do and cheap.
Old Apr 19, 2007 | 05:51 PM
jakeiscool's Avatar
Banned
bondo isnt really used anymore. body filler is GARBAGE for the most part. A new oe fender is like 60 bucks max.
Old Apr 19, 2007 | 06:00 PM
fastasssr20's Avatar
time is money, and fixin it might take a lot of time if you dont know what ur doin. I would just get a used fender u never know you might even get one the same color as ur car.
Old Apr 19, 2007 | 06:06 PM
jakeiscool's Avatar
Banned
Default Re: (fastasssr20)
my god I thought 06' was bad.
Old Apr 19, 2007 | 06:37 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (JakeIsCool)
metal glaze can fill some pretty deep scratches or some minor minor door dings from cars! but tap out the dent some with a hammer first before using metal glaze! the less filler the better!
Old Apr 21, 2007 | 10:53 AM
mike9571's Avatar
Default Re: (B16B_coupe)
First it needs to be pulled out. Then weld the hole shut, if you dont weld it shut the filler will absorb moisture and crack. MUCH MUCH easier buy a new fender for like 20bucks
farkiller
Aug 8, 2009 04:40 AM
pumafoot
10
Feb 4, 2007 10:20 AM
Dforce
Jan 5, 2007 03:50 PM
No2Pencil
24
Jan 5, 2007 06:19 AM
Felliph3
20
Oct 11, 2006 11:26 AM
