Anyone know what kind of resistor they use to make blinkers slow down?
Old Apr 19, 2007 | 03:37 PM
Mag00n's Avatar
Default Anyone know what kind of resistor they use to make blinkers slow down?
My bike has inline resistors im guessing to slow the rate of blinking...but one of them fell off and since then the left blinker doesnt work. Well i tried just wiring the wires directly but it keeps blowing a fuse and smoking i dont know why maybe because all the other wires are still on resistors? So what kind of resistor do i need and can i get them at home depot or anywhere local?
Old Apr 19, 2007 | 06:49 PM
EGlovr's Avatar
Default Re: Anyone know what kind of resistor they use to make blinkers slow down? (Mag00n)
are you sure the left blinker isn't working because a resistor fell off?
my diagnosis would be that the left bulb just needs to be replaced
.02
Old Apr 19, 2007 | 07:17 PM
Mag00n's Avatar
Default Re: Anyone know what kind of resistor they use to make blinkers slow down? (EGlovr)
it is not the bulb
Old Apr 19, 2007 | 07:27 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
If it's a blown resistor, which is pretty rare, it should just blink fast. If its not blinking, you should check to make sure that the bulb is getting juice. Also check the ground at the bulb. Then check the switch to see if it's throwing juice out the left. Are there separate left and right turn signal fuses?
Old Apr 19, 2007 | 07:30 PM
Mag00n's Avatar
Default Re: Anyone know what kind of resistor they use to make blinkers slow down? (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">If it's a blown resistor, which is pretty rare, it should just blink fast. If its not blinking, you should check to make sure that the bulb is getting juice. Also check the ground at the bulb. Then check the switch to see if it's throwing juice out the left.</TD></TR></TABLE>
the resistor is GONE not blown i just want to know what kind of resistor it is and if i can get it at locally
Yes ive already tested it ona multimeter and swapped the bulbs im SURE its the fact the resistor is GONE.
Old Apr 19, 2007 | 07:31 PM
ScareyH22A's Avatar
Community Builder
Is it LED's or a bulb?
R = (VS - VL) / I
VS = supply voltage
VL = LED voltage (usually 2V, but 4V for blue and white LEDs)
I = LED current (e.g. 20mA), this must be less than the maximum permitted
So like a 12V system minus a 2V led divided by 20mA (0.02A) = 500ohm resistor
Old Apr 19, 2007 | 07:50 PM
Mag00n's Avatar
its just a bulb up front no led's
so its just 500 resistor they are all the same? Do i need anything else to get the bare wire into the resistor? sorry im totally clueless when it comes to electrical
do you know why it smokes and blows the fuse every single time i connect the wire without the resistor
Old Apr 19, 2007 | 07:58 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">its just a bulb up front no led's
do you know why it smokes and blows the fuse every single time i connect the wire without the resistor</TD></TR></TABLE>
usually means there's a short. i dont think its the resistor really. but yea.. 500 to 850 should do the trick even with a bulb. i'd just grab a few from 100 to 1000 and use the highest ones 1st. then lower the values until ur happy. if it doesnt seem high enough with the 1000, just line up a few of them in series to add resistance.
eghatchin
16
Apr 25, 2008 04:46 PM
Ghuy
Apr 24, 2008 07:46 AM
si90rex
11
Jan 31, 2008 06:40 PM
bogus_ek
Feb 9, 2005 06:47 AM
TedR719
14
Apr 21, 2004 07:17 AM
