WHat harnest to get?
Old Apr 19, 2007 | 02:12 PM
20ls01's Avatar
Default What harness to get?
2001 integra
and this is the deck im getting
http://www.circuitcity.com/ccd...NGERS
Modified by 20ls01 at 3:30 PM 4/19/2007
Old Apr 19, 2007 | 02:40 PM
myfirstdc2's Avatar
Default Re: What harness to get? (20ls01)
what do u mean what harness?
Old Apr 19, 2007 | 04:32 PM
NzAnE2K's Avatar
If you're talking about a wiring harness, this one should work:
http://www.cardomain.com/item/SCOHA02B
Old Apr 19, 2007 | 09:02 PM
K2sInteg98's Avatar
Default Re: (20ls01)
no, your gonna have to do some crimping with wires. Once you have the harness, it will be a breeze, just connect all the matching wires.
Old Apr 19, 2007 | 09:19 PM
NzAnE2K's Avatar
As K2sInteg98 said, you need to either crimp the wires or you can solder them. The Scoche harness doesn't come with the piece that you use to crimp the two wires together, so you can either buy some (you can find them for cheap at any hardware store rather than buying an installation kit), or just solder the two wires. I wouldn't recommend just twisting the two pairs together as it comes apart easily and the contact between the two wires won't be that great. The Sony headunit should have some bare wires, and all you have to do is color-match the two wires, plug one end to the car and the other end to the Sony unit. There should be a diagram included so it shouldn't be too hard.
Old Apr 19, 2007 | 09:24 PM
davidluko's Avatar
There should be a harness sticking out of the back of the headunit. If not, you can probalby find one on ebay that works. Then you get the plug that'll plug into the radio plug like the one NzAnE2K posted (you can also get it at any decent local stereo shop if you don't want to wait for shipping[at the same time, you can buy a stereo install kit]). Once you have both of those, crimp or solder the wires together by color (match the colors up).
Old Apr 19, 2007 | 09:26 PM
myfirstdc2's Avatar
usually when u buy a new unit it comes wiht the harness. all u need to buy is the honda adapter harness. its about 10 bucks. then just connect the wires together with either crimp terminals or solder it. and make sure u ground the unit well or u will get whining noise. i usually ground mine direct i dont like using the stock ground.
Old Apr 20, 2007 | 12:17 PM
Pee Wee's Avatar
you need the $10 "jumper harness" (haha) from wal-mart or wherever. just use some but connectors to put em together
Old Apr 20, 2007 | 01:19 PM
davidluko's Avatar
If that little plug plugs into the head unit, just cut the big one off and attach the right one that'll fit into your Integra.
Old Apr 21, 2007 | 08:54 AM
kinick313's Avatar
you can figure that out yourself. I don't know whether that old of civic had the same wiring as the G3 integras, but just look at the pins and figure out which pin does what function on both the HU side and the car side, and see if they correspond. Somewhere on this site I've seen the body wiring for the radio, and the sony's wiring will be in your manual.
Old Apr 21, 2007 | 09:34 AM
TsujenDB1's Avatar
If your buying the cd player from ccity ask them for a harness
Old Apr 22, 2007 | 12:18 AM
vladd's Avatar
i bought an integra harness for 7 bucks from a local car audio place. if you don't want to spend a couple bucks and do it right then you could always do it the ghetto way; snip the plug off the in-car wiring and wire the stereo directly to the car wiring. you're going to have to crimp or solder the wires either way you do it.
ericnoss
Engine Management and Tuning
May 16, 2013 08:15 PM
Zhu962
Apr 16, 2009 07:57 PM
JDM_EK_JOE
Oct 17, 2007 02:23 PM
B16CRXT
Dec 12, 2004 03:23 AM
towns
Apr 22, 2004 02:14 PM
