valve relief question
Old Apr 19, 2007 | 01:54 PM
iskate2's Avatar
Default valve relief question
Im about to have my b16 cylinder head refurbished, and im thinking of going with oversized valves. The question is, will the valve reliefs in the stock bore CTR pistons accomodate 1mm oversized valves? I do have the ability to machine the reliefs out larger, but it is a very tedious process and I would rather not take weight out from an otherwise rather balanced set of pistons. Any help would be appreciated.
-matt
Old Apr 19, 2007 | 04:04 PM
BILLETGRIP's Avatar
Default Re: valve relief question (iskate2)
measure the diameter of the reliefs. if the intake relief is bigger than 1.339 (34mm) and the exhaust relief is bigger than 1.142 (29mm) i would assume that they would work but i dont know for sure. plus if you take the same amount off all the pistons they should stay balanced.
mayfly
Jun 17, 2012 09:17 AM
gs1gsr
Jan 9, 2008 09:30 PM
Hockey27925
Dec 22, 2004 08:11 PM
LudeyKrus
Jun 30, 2003 08:26 AM
