HOTROD UPDATE:Mike Brown's 1993 Integra
Here are a few pics of Mike Brown's HotRod Integra. The car has undergone MAJOR changes to be competitive in the HOT ROD class.
All work performed by:
Advanced Automotive Concepts
410-661-7799
DreamWorks AutoBody & Performance Inc.
410-483-6225
[IMG][http://i130.photobucket.com/albums/p...F0159.jpg/IMG]
[IMG]http://i130.photobucket.com/albums/p255/boogiedownbrown/DSCF0154.jpg[IMG]
Modified by BoogieDownBrown at 2:14 PM 4/19/2007
Modified by BoogieDownBrown at 2:19 PM 4/19/2007
Modified by BoogieDownBrown at 2:21 PM 4/19/2007
410-661-7799
410-483-6225
Don't take this the wrong way, but i'd find away for some additional support for those wastegates. All that weight vibrating causes cracks almost every time at the wg to collector weld. The further the gates are from the collector, the more likely it is to happen. I've had 1 of mine break there, and seen tons of others do the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Don't take this the wrong way, but i'd find away for some additional support for those wastegates. All that weight vibrating causes cracks almost every time at the wg to collector weld. The further the gates are from the collector, the more likely it is to happen. I've had 1 of mine break there, and seen tons of others do the same.
Thanx Tony, Changes are being made right now.
</TD></TR></TABLE>Thanx Tony, Changes are being made right now.
Do you have pics of what you did to fix/brace it?
</TD></TR></TABLE>Do you have pics of what you did to fix/brace it?
Looks good. I'm curious as to why such a long header. Big turbo small engine long manifolds don't exactly help when you need heat and velocity to make a turbo happy. But good to see another privateer honda hotrod.
I looked through all my pics, i only have before pics. Kinda hard to explain how i did it. I don't see a brace on the manifold, and it's definitely going to need one, so they can probably incorporate something into that brace to support the wastegates.
I THINK the second WG was welded to that mani by Joe S. I could be wrong though, he did one for him last year added a 2nd gate cuz of boost creep I think. Unless they changed manifolds which I know Mike was in the process of doing also
Looking good Mike and Aaron.
</TD></TR></TABLE>I THINK the second WG was welded to that mani by Joe S. I could be wrong though, he did one for him last year added a 2nd gate cuz of boost creep I think. Unless they changed manifolds which I know Mike was in the process of doing also
To answer a few questions.
It does not use a stock oil systems so oil draining back to the turbo wont be a problem.
The trans is for mock up. The trans thats going in is a liberty 4 speed with bell housing.
We will be bracing the manifold and wastegates.
Burns gave us the length for the runners they are a little longer than what they recommended but sould be fine. The manifold is made out of 321 ss.
Thanks for the support see yall at the track soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">
Thanx.... we are so close but still so far away. Plans are to be at Atco.
</TD></TR></TABLE>Thanx.... we are so close but still so far away. Plans are to be at Atco.
very sick!! i am about to start building an all-motor drag DA and would like to pick ur brain. i have no idea where to begin building a cage. if u have any more indepth pics i would love to see them. u can send them to my e-mail pulseautosound@hotmail.com
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. »</TD></TR><TR><TD CLASS="quote">why the cable tranny still?</TD></TR></TABLE>
if you look, the clutch pedal has a master cyl on it. the cable trans is probably there for mock up purposes. i know Mike has a special trans on the way.
looking good
looking good
yea the cable trans is for mock up only, just like mike said, we're going to run a 4speed liberty trans, like mike said.
Martin
Martin
Wow, my crew chief made a post. Thanks for the love folks I'll have more pics closer to completion next week. We actually got a lot of **** done today, looks different than the pictures posted by Mr. Brown. I'm sure he saw it and snapped a few when he got back to the chassis shop.
