stock sleeves d16z6
Old Apr 19, 2007 | 09:19 AM
94c1v1cex's Avatar
Default stock sleeves d16z6
how much whp can my d16z6 take on stock sleeves? boosted of course... with forged pistons and rods... new valves valve springs and titanium retainers and stage 2 cam?
Old Apr 19, 2007 | 09:36 AM
doood's Avatar
been there done that
Default Re: stock sleeves d16z6 (94c1v1cex)
400 if you're feeling lucky
Old Apr 19, 2007 | 01:15 PM
SoHc94's Avatar
well... how bout u do a write up for us.... just keep adding stuff. sacrifice for the team an let US all no how much our stock sleeves can handle...
Old Apr 19, 2007 | 01:20 PM
97Ej6mike's Avatar
10 psi?
Old Apr 19, 2007 | 01:22 PM
dohcdelsol's Avatar
Default Re: (97Ej6mike)
depends on the tune and psi ur running but i would say 350-400MAX whp.
pinks car hit 400whp stock sleeves.
Old Apr 19, 2007 | 02:05 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">10 psi?</TD></TR></TABLE>
he said power not psi. which is irrelevant anyway.
Old Apr 19, 2007 | 05:50 PM
94c1v1cex's Avatar
Default Re: stock sleeves d16z6 (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">400 if you're feeling lucky </TD></TR></TABLE>
cool all i want to run is 325 thanks guys
Old Apr 19, 2007 | 06:11 PM
94c1v1cex's Avatar
probably 12-15 psi
its a small turbo tho i dont want to put a t3/t4 in it i'm puttint in a greddy tdo4h
Old Apr 19, 2007 | 06:54 PM
SoHc94's Avatar
im honored that im in yur sig...
Old Apr 19, 2007 | 07:46 PM
1995Civic's Avatar
Default Re: (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">
probably 12-15 psi
its a small turbo tho i dont want to put a t3/t4 in it i'm puttint in a greddy tdo4h</TD></TR></TABLE>
Like stated by 'dood' PSI is completely irrelevant.
The D16z6 can handle just about 400whp on stock sleeves, as long as the block is in good condition. Sleeves are not the first weak point on this motor, the ringlands are.
What pistons/rods are you putting in the build?
Old Apr 20, 2007 | 11:57 AM
94c1v1cex's Avatar
Default Re: (SoHc94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 &raquo;</TD></TR><TR><TD CLASS="quote">im honored that im in yur sig...</TD></TR></TABLE>
man me and my friend laughed our asses off when we read that had to put it there
Old Apr 20, 2007 | 11:58 AM
94c1v1cex's Avatar
Default Re: (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">Like stated by 'dood' PSI is completely irrelevant.
What pistons/rods are you putting in the build?</TD></TR></TABLE>
cp pistons and eagle rods probably also looking at srp pistons but i'm leaning towards cp but eagle rods fo sho
what compression pistons should i run? suggestions?
Old Apr 20, 2007 | 02:41 PM
SoHc94's Avatar
Old Apr 20, 2007 | 02:47 PM
spork motorsports's Avatar
* B A N N E D *
vitara's are cheap as expletive and knock a little, can easily take 300+ whp and in excess of 25 ponds of boost on a tdo4h 1st gen
seriously you could get them from a 98-99 vitara also known as G16B pistons suzuki
Old Apr 20, 2007 | 04:46 PM
94c1v1cex's Avatar
Default Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">vitara's are cheap as expletive and knock a little, can easily take 300+ whp and in excess of 25 ponds of boost on a tdo4h 1st gen
seriously you could get them from a 98-99 vitara also known as G16B pistons suzuki</TD></TR></TABLE>
well i'm gonna spend the money to do it right cause i will eventually go to a bigger turbo and get it sleeved later for sure
Old Apr 20, 2007 | 04:55 PM
Vt3c_eg's Avatar
http://www.turbod16.com/viewto...stall
read this link and listen to Rota92.
Old Apr 20, 2007 | 05:51 PM
1995Civic's Avatar
what compression pistons should i run? suggestions?</TD></TR></TABLE>
I personally went with CP pistons and Crower Rods (yea $700).
Eagle Rods work very well too...with Crower however, you dont need to notch the cylinder walls...eagles, tuner toys, scat, etc. you will have to.
With CP I would get the 9.0:1 compression, and with a Cometic MLS Headgasket, you will be even lower.
Old Apr 20, 2007 | 05:53 PM
1995Civic's Avatar
well i'm gonna spend the money to do it right cause i will eventually go to a bigger turbo and get it sleeved later for sure</TD></TR></TABLE>
Why do you want to sleeve it?
How much power are you looking for, and what turbo do you plan on running?
Old Apr 20, 2007 | 05:59 PM
94c1v1cex's Avatar
i'm not sure if i will keep this motor i might swap to a b18b or b18c in the next couple years but if i dont i will sleeve this one and go to a t3/t4 turbo and get as much power as i can
Old Apr 20, 2007 | 06:03 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">i'm not sure if i will keep this motor i might swap to a b18b or b18c in the next couple years but if i dont i will sleeve this one and go to a t3/t4 turbo and get as much power as i can</TD></TR></TABLE>
From the sounds of it, you're not looking to make this a track car huh?
You have to tell me what "As much power as i can" means...I can tell you how to make a good 250whp DD or a 400whp track car w/ that motor.
You just have to explain what your goals are
Old Apr 20, 2007 | 06:05 PM
* B A N N E D *
its not THAT hard to notch a block, i mean you could do it with a dremal if the block is bare, and just hot tank or batch it when your done cutting, its time consuming and youll go through bits like nothing but if your on THAT tight of a budget it works, either that or just go buy a real cutoff wheel/grinder, also vitara;s imho are not a "half-assed" build but it doesnt get you the magizine credential or the show scene hyped becuase you used 100 dollar cast pistons
the metal used in the casting process of the vitara's is equal to or greather in that forged metal used on typical aftermarket pistons
not al fogeing processes are better than all casting it really depends on the type of materials used and the process it has been through
Old Apr 20, 2007 | 06:07 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">its not THAT hard to notch a block, i mean you could do it with a dremal if the block is bare, and just hot tank or batch it when your done cutting, its time consuming and youll go through bits like nothing but if your on THAT tight of a budget it works, either that or just go buy a real cutoff wheel/grinder, also vitara;s imho are not a "half-assed" build but it doesnt get you the magizine credential or the show scene hyped becuase you used 100 dollar cast pistons
I didnt say it was hard...I was simply stating that he wouldnt have to do it with Crower Rods. Thats all.
Hard?..not at all. I was just informing him in case he didnt know.
* B A N N E D *
a t3/t4 turbine is imh too big for that biggest turbo id go for roadrace daily to get some torque low end is a t3 saab, but imho THE BEST turbo for a d16z6 is a tdo4h first gen mitsu
turn it up to 25 psi the viatras and stock sleeves can handle it on a good tune and just daily drive that biach
Old Apr 20, 2007 | 06:14 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">a t3/t4 turbine is imh too big for that biggest turbo id go for roadrace daily to get some torque low end is a t3 saab, but imho THE BEST turbo for a d16z6 is a tdo4h first gen mitsu
turn it up to 25 psi the viatras and stock sleeves can handle it on a good tune and just daily drive that biach</TD></TR></TABLE>
Hellll no the t3/t4 turbo is not too big for this motor when its fully built...i think its much too big for a stock turbo setup, but not when built on 25lbs.
Besides, Vitara's have proven to hold up to 400whp, however they are still a cast piston that I wouldnt rely on too heavily.
I have a z6 motor being fully built w/ CP pistons and Crower Rods, and obviously other parts w/ a Precision SC61 going on that bitch...t3/t4? perfectly fine.
Old Apr 20, 2007 | 08:37 PM
94c1v1cex's Avatar
my thing is i want a dependable daily driver that has that 325-350 hp to smoke anything that rolls up on me around here... (not alot of power around here) but there are a few people that think they are the **** with theyre camaros that are slow as ****...
in another thread i talked about a good friend of mine that has a fully built minime boosted w/ a garret t3/t4 hes at 413 whp and that car is ****** quick nothing around here has a chance hes got well over 15k in that car its ridiculous... and he's only let me drive it like 4 or 5 times haha
but he daily drives it and drops a gear and kicks *** when he needs too haha
thats what i want... just minus about 75 hp and a shitload of money...
