Horn wont work.. no power to horn
Old Apr 19, 2007 | 09:00 AM
VTEC-LUDE's Avatar
Default Horn wont work.. no power to horn
I took my horn off as i thought it was broken, but when I tested it on my JDM Honda Prelude VTEC it worked fine.
I checked the power to the wires and there was none when the horn buttons where pressed. I dont know where to look now. All the Fuses are fine.
That horn stopped working when i drove trhough a flood, it died slowly and never worked, even though it does actually work.
Any ideas... could anything be unplugged- i took the aribag out and plugged it back in the other day. But i dont think that had anything to do with it as it wasnt working before that
Old Apr 19, 2007 | 10:04 AM
Relic1's Avatar
which car?
does your brake lights work?
Old Apr 19, 2007 | 03:10 PM
reeder321's Avatar
Default Re: Horn wont work.. no power to horn (VTEC-LUDE)
Do you hear the relay click when you press the horn button?
I had this problem. the fuses where fine, and when I pressed the horn button I could hear the relay click. I turned out that one of the wires going to the horn had split and corroded. Luckily it was in the last couple of feet of wire close to the horn so I just cut it off and spliced some new wires on.
B00stedEh3
Aug 1, 2010 07:28 PM
zenon8890
10
Feb 7, 2008 07:06 AM
Redemption
Jun 24, 2007 03:18 PM
spoolinegsr
Nov 5, 2006 09:00 PM
ferio 95
Dec 29, 2003 04:04 PM
