What ya think about this?
Old Apr 19, 2007 | 08:28 AM
jravensc's Avatar
Default What ya think about this?
So i a few weeks ago i threw a P0420. I had notice before that my motor/exhaust sounded a little louder. i worried that it was gonna be the cat. but after some inspection i find this
now i dont pretend to be a mechanical genius, but im pretty sure i shouldn't be able to put a butter knife into my cylinder head. any suggestions other than the obvious. get honda parts, or something generic? will this cause a 0420? 1999 accord ex 4 cylinder.
thanks in advance.
justin
Old Apr 19, 2007 | 08:51 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: What ya think about this? (jravensc)
thats nothing to worry about. Those are just voids in the casting of the head. Thats not actually the exhaust ports.
I'll see if I can find a picture to show you what I mean.
Old Apr 19, 2007 | 09:01 AM
rhdune16's Avatar
i believe it's these voids... pic taken during my build...
Old Apr 19, 2007 | 09:03 AM
jravensc's Avatar
Default Re: (rhdune16)
yeah that would make sense. the gaps are offset from the manifold cylinders.
Old Apr 19, 2007 | 09:06 AM
jravensc's Avatar
Default Re: (jravensc)
back to square 1
Old Apr 19, 2007 | 09:07 AM
H-T Order of Merit
these are a couple pictures I used from a while ago when someone asked the same thing. But rhdune16's picture shows it better
Old Apr 19, 2007 | 09:21 AM
Cronousman's Avatar
that is the code for either cat or 02 sensor...for a 1999 it sounds like cat failure is unlikely...unless you have a lot of miles or put something you shouldnt put into your tank...
Old Apr 19, 2007 | 09:37 AM
jravensc's Avatar
Default Re: What ya think about this? (Cronousman)
115,000 miles
Old Apr 19, 2007 | 09:41 AM
jravensc's Avatar
and i do notice a lot of exhaust noise. seems to be coming from the engine bay. i have heard that cracks in the manifold can trip this code. i guess i am curious as to which o2 sensor is triggering this code. there is one in the cat. correct?
Old Apr 19, 2007 | 10:40 AM
jravensc's Avatar
not to beat a dead horse here, but wouldn't an o2 sensor malufunction trigger an o2 sensor malfunction code? not one about cat efficiency?
Old Apr 19, 2007 | 12:02 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cronousman &raquo;</TD></TR><TR><TD CLASS="quote">that is the code for either cat or 02 sensor...for a 1999 it sounds like cat failure is unlikely...unless you have a lot of miles or put something you shouldnt put into your tank...</TD></TR></TABLE>
The catalytic converters on 98-02 Accords are notorious for failing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jravensc &raquo;</TD></TR><TR><TD CLASS="quote">not to beat a dead horse here, but wouldn't an o2 sensor malufunction trigger an o2 sensor malfunction code? not one about cat efficiency? </TD></TR></TABLE>
Typically, yes, but unfortunately that's not always the case.
Try to track down the exhaust leak. While a friend steps on the gas a bit, you can try to feel for the escaping air. (Obviously, be careful not to touch the exhaust while it's hot.) The flex joint is a common leak point.
I found my friend's exhaust leak by accident, when I Seafoam'd his car. I was giving it some gas as smoke was pouring from his exhaust pipe, when I noticed a little bit of smoke coming from underneath the car. Coincidentally, it was the flex joint that was leaking.
Old Apr 19, 2007 | 12:12 PM
hurleyint's Avatar
Default Re: What ya think about this? (philadd)
Have you checked the downpipe portion of the manifold?
Nighthawk91
Apr 24, 2014 06:19 PM
TravisBiggie
Mar 6, 2014 10:19 AM
K20ISR
Honda Civic (2006 - 2015)
Aug 21, 2008 09:27 AM
tak1civic
Sep 16, 2006 06:31 PM
TRH
Sep 23, 2003 06:55 PM
