car died !!
i have a 95 civic ex turbo !!! so i was driving and everything is fine wen i got to da stop light and went to stop da car shut off and it wouldnt start back up !!! can anyone help me out !! i cannot figure out wats wrong with it !!
Well you want to check for spark for sure... if your not getting spark theres an ICM in the distributor that went bad on my 93 Si and I had to replace the distributor. Check your ignition fuse under the hood and under the dash you may have blew one, that will cut spark. Did you possibly jump time? you may want to take a look at that... but the car was running fine previous to this red light im assuming?
check for spark if good, and 100% sure fuel pump is working check to see if injectors are opening, noid light or test light will work.. get back if nothing helps u.. what are the condtion of the plugs
ok did u make sure u grounded all yur wires? i left that valve cover ground off by . accident on my swap.. blew the crank sensor. car wouldnt start. had to get a new dizzy. if yur cam gear is exposed make sure that u didnt jump the timing. or just make sure yur rotor is spinning. check all yur fuses. u may have blew one.
MetalKill
10
Jan 30, 2003 07:42 AM
Elite Hatch
Dec 19, 2002 06:18 PM
