No oil holes on big needle bearing in transmission housing?
Old Apr 18, 2007 | 07:45 PM
GRM Scott's Avatar
25 Year Member
Default No oil holes on big needle bearing in transmission housing?
I'm still banging my head against this silly transmission, finally got around to completely disassembling the countershaft in case that's where the problem was. In so doing, D pointed out that the needle bearing that rests in the housing (number 18 below) should have oil holes facing up when installed. The bearing I've got in there is the proper size, but has no holes on either face.
Is this cause for concern? I'm pretty sure it was a Honda part, unless the place I sent the transmission to that screwed everything up in the first place used some identically-sized part from a different car. Just wonder if anyone has encountered this before.
Old Apr 18, 2007 | 07:54 PM
RTW DC2R's Avatar
Ive replaced that needle bearing twice in the past few months, and AFAIK I dont recall there being any oil holes on it, top or bottom. heres a closer pic of the diagram and its exactly what it looks like. Also note the Civic SI part is the exact same and about $20 cheaper through Honda compared to the Acura part.
Old Apr 19, 2007 | 06:47 AM
len's Avatar
len
Default Re: No oil holes on big needle bearing in transmission housing? (GRM Scott)
I have that part in my hands right now. PN#91101-P80-008
One side has markings on them. "HL" "NTN" "HL-8E-NK 33X60X20-11"
No oil holes.
Old Apr 19, 2007 | 07:01 AM
walker111's Avatar
Default Re: No oil holes on big needle bearing in transmission housing? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">I have that part in my hands right now. PN#91101-P80-008
No oil holes.</TD></TR></TABLE>
Old Apr 19, 2007 | 08:25 AM
GRM Scott's Avatar
25 Year Member
Default Re: No oil holes on big needle bearing in transmission housing? (walker111)
Sweet, thanks for the confirmation guys.
Old Apr 19, 2007 | 08:46 AM
D's Avatar
D
Good info. The Helm manual is pretty explicit regarding installation of this CS bearing with the oil holes facing up, and from memory, the 3 tranny's i have in my garage all have said oil holes.
Len, can you look at part #/history and see what revisions/updates have taken place over the life of said part?
Old Apr 19, 2007 | 10:59 AM
IN VTEC's Avatar
I've had a mixed bag with the oil holes. The LS transmission I did didn't have them, but the last two GS-R transmissions I've rebuilt have had them. None of the D-series transmissions have had the oil holes.
Old Apr 19, 2007 | 11:37 AM
RTW DC2R's Avatar
I still have the 2 bearings I recently removed from my trans. One is the OEM bearing that was in the trans from the factory, the other is from Honda for a Civic SI trans.
They actually have different numbers on them but the dont have the oil holes. Both sides look exactly the same except for the stamped part number.
(some of the numbers are hard to read)
HL NTN HL 8E-NK-33X60X20-11 CU
JAPAN GS NTN 8E-NK33X60X20-8
craftech
10
Oct 1, 2008 03:48 PM
red_crx
Aug 20, 2007 08:15 AM
spooledhonda
Mar 9, 2006 03:17 PM
mike_belben@yahoo.com
Mar 2, 2005 06:48 PM
dustin
Oct 23, 2002 12:06 PM
