where is rpm signal?
Old Apr 18, 2007 | 07:00 PM
VTEC_PRODUCTION's Avatar
Default where is rpm signal?
anyone know where the rpm signal on the ecu is? i have a chart here but im not sure where it is...
http://tech2.hybridgarage.com/..._obd1
and
http://technet.ff-squad.com/wiring.obd1.htm
sorry i dont really know which is the correct one im still trying to figure this out the colors dont match but the wire locations do....
thank you for the help in advance...
Old Apr 18, 2007 | 07:22 PM
OMG THE GOGGLES's Avatar
Default Re: where is rpm signal? (Acura_Integra_Type_R)
Usually blue with white stripe on honders. There is also one you can tap into under the hood behind your brake reservoir that comes from your dist, and also behind your guage cluster..same wire also, blue with white stripe. That is your RPM signal.
Old Apr 18, 2007 | 08:08 PM
Default Re: where is rpm signal? (gasp0matikz)
i would prefer one near the ecu since im hooking up a piggyback with that wire...but if there isnt one then i guess i will just run a long wire or something...
Old Apr 18, 2007 | 08:53 PM
If you download an install manual for a piggyback system like any of the Apexi afc's, it will tell you the wire and pinout. I remember from the ones I have soldered into peoples harness' that have brought those things to me. Just download the manual and it will show you at the point of the ECU.
Old Apr 19, 2007 | 05:27 AM
bump for any other suggestions...
boosted k20
Mar 2, 2011 03:33 AM
heyitzspikey
Nov 29, 2005 05:23 PM
Weapon_R
Sep 17, 2004 11:26 AM
delslowh23
Sep 13, 2004 05:37 AM
InLimbo87
Jul 3, 2004 09:12 PM
