sport button light blinking on and off and the car seems to loose power
i have a 1990 honda accord 4 door automatic...and it has the sport button... when i drive sometimes the light for the sport button start blinking on and off and the car seems to loose power !!!!!! can anybody help me please???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecb7 »</TD></TR><TR><TD CLASS="quote">i would replace the transmission ecu. its next to the engine ecu but its smaller.</TD></TR></TABLE>
You got horrible grammar.
When the A/T control unit senses an abnormality in the input or output systems, the S indicator light in the gauge
assembly will blink at equal intervals and the LED display on the A/T control unit will blink a problem code when the ignition
key is turned on. However, when the Service Check Connector (located to the lower right of the glove compartment)
is shorted with a jumper wire, the S indicator light will also blink the problem code when the ignition switch is turned on.
When the S indicator light has been reported on, short the two terminals of the Service Check Connector together or pull
the passenger's side carpet down from under the dashboard. Then turn on the ignition switch and observe either the S indicator
light or the A/T control unit LED display.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 »</TD></TR><TR><TD CLASS="quote">You got horrible grammar.</TD></TR></TABLE>
Don't nit pick. There are many other posts that are so hard to read/understand it's not even funny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BORACHO »</TD></TR><TR><TD CLASS="quote">anybody else?????????????????</TD></TR></TABLE>
haha, did you not believe me?
BEFORE you start throwing money at the problem; use this link to get the trans control unit Code. The 'S' light will blink a code;
http://members.troublecodes.ne...n.jpg
For your year car 90% of the time there is a code it is an electrical problem.
menpachi
Honda Civic (2001 - 2005)
Oct 30, 2007 03:01 PM
1320king
Jul 22, 2007 12:32 PM
naptownrex
10
Apr 18, 2005 08:26 PM
