My CRX Battery fuse
Old Apr 18, 2007 | 02:35 PM
crxaggtown's Avatar
Default My CRX Battery fuse
i got a 1989 crx and just recently i was driving and it turned off ....i saw that the battery fuse was messed up so i replaced it and it turned back on but it only lasted a couple of minutes and that one popped too.ive replaced it 3 times .Does any body have an idea about it. (i dont know if this will help but i noticed like a couple of minutes before it messed up my temp was on high and my car was only running for 10-20 minutes and after i saw that it was high it calmed down back to normal and then it messed up)
Old Apr 18, 2007 | 03:03 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: My CRX Battery fuse (crxaggtown)
A good place to start would be to check your grounds and that no 12V wires are exposed and grounding out. Start with the battery to tranny to frame ground and the positive wires running to your fusebox.
Old Apr 18, 2007 | 05:38 PM
SFlCrx's Avatar
check to see if the power wire to the alternator from the bat. is grounding too
GPC91
May 7, 2013 09:06 PM
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
Ruben19
Oct 10, 2007 08:49 AM
R-81DC2
Jun 5, 2007 09:21 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
