manual or auto ?
Old Apr 18, 2007 | 02:15 PM
hany's Avatar
Default manual or auto ?
i know its strange question . but answer will help me to buy an engine.
if i have an engine without tranny or ecu . how can i know if that engine was manual or auto?
Old Apr 18, 2007 | 02:18 PM
sony224422's Avatar
Default Re: manual or auto ? (hany)
manual will mostlikely have a flywheel attachted to it still. It doesn't matter, you could get either, as long as you have the parts to put in as a manual or auto. All the engines are made the same, its just the hardware for the drivetrain thats different.
Old Apr 18, 2007 | 02:44 PM
hany's Avatar
Default Re: manual or auto ? (sony224422)
i need to buy the auto engine because it always be in better health thatn the manual. but iam afraied that the seller put any auto tranny in manual engine and say to me take here is its auto engine as i said.
inderstand me ?
so is there are any info or code on the engine tell that the engine was an auto ?
Old Apr 18, 2007 | 03:17 PM
Bakeoff's Avatar
I have no idea what you just said, but like the other guy said, there is no difference in the motors. Unless you have someone honest or you took it out yourself, there is no way to tell. And really, does it matter? Who's to say it was abused more? My neighbor has had a 95 civic ex that's a 5spd for 10 years and she's almost 60. Think she's ever revved it to redline? doubtful.
Old Apr 18, 2007 | 03:23 PM
sony224422's Avatar
Default Re: manual or auto ? (Bakeoff)
yeah, all the codes on the engine are the same. It won't matter about what tranny was attatched to it, it matters more about the maintance and such. just because the car was a manual doesn't mean it wasn't taken care of, it'd be more worried about the maintance of the engine, seeing that thats what makes or breaks (litterally) the engine.
Old Apr 20, 2007 | 01:51 PM
hany's Avatar
yes its ok get it now thanks alot for helping.
Old Apr 20, 2007 | 03:01 PM
jaretron3030's Avatar
always thought auto engines had different cams? no?
Old Apr 20, 2007 | 05:59 PM
twinj's Avatar
^^ I heard that too.
Old Apr 20, 2007 | 06:04 PM
SkertySkerty's Avatar
Default Re: (jaretron3030)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaretron3030 &raquo;</TD></TR><TR><TD CLASS="quote">always thought auto engines had different cams? no?</TD></TR></TABLE>
thats a big big myth.. i had someone tell me this a couple of time hey take and put the ls auto cams into your ls manual... went to honda and asked them myself its the exact same part number and specs
Old Apr 20, 2007 | 06:19 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (SkertySkerty)
not true. about the cams&lt;
all motors are the same
trannys Change only.
Old Apr 20, 2007 | 07:19 PM
hondamark35's Avatar
there is one thing on certain motors that can tell you if it was manual or auto and it likely won't matter in most cases cuz it's easy to switch around. somtimes the intake manifold/TB have different brackets and iacv locations.
so basically it's all in the intake and that's it. if you have a manual ecu and harness and the manifold all hooks up right then you're good. but these guys are all right, there really is no significant difference between the auto and manual motors.
Old Apr 20, 2007 | 08:05 PM
NOFX's Avatar
H-T White Ops
If there's a VIN on the block you can also tell.
Old Apr 21, 2007 | 12:43 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (NOFX)
if it is a longblock the intake manifolds are diffrent, the auto has another throttle cable leading to the trans, and will have a necessary spot for the cable, also the vin helps.
eguti66
Nov 4, 2009 12:26 PM
superturboprelude
Jun 26, 2005 05:38 PM
pierreram
Acura TL, RL & ZDX
Aug 8, 2003 10:21 PM
Mrfirefox
Jul 23, 2002 08:20 AM
