ecu ????
Old Apr 18, 2007 | 01:32 PM
dylokjai's Avatar
Default ecu ????
my 88 crx is currently running a p06 ecu w/ minime no vtec so if i get a hold of a p28 ecu will it be plug and play(after i add couple of wires) or is there another ecu i can use beside p28?
Old Apr 18, 2007 | 01:53 PM
dumped4dr's Avatar
Default Re: ecu ???? (dylokjai)
no plug and play....
u need more stuff like obd1 injectors, a jumper harness (or u could rewire urself) and i think theres a few more things... i havent done it in a while. search for obd0 - obd1 conversion
Old Apr 19, 2007 | 01:44 AM
dylokjai's Avatar
Default Re: ecu ???? (dumped4dr)
im currently running a p06 ecu that would be a obd1 ecu right? so if im running that ecu cant i just add the vtec wires to the p28 and im done?
Old Apr 19, 2007 | 02:43 AM
BlueCrxNC's Avatar
Yes, the P06 is OBD1 so you won't need to change injectors etc. You will need to add the VTEC wires from the ECU to the actual sensors on the motor if they aren't there already.
You know, you can actually convert your P06 to run VTEC (ie. P06 to P28 Conversion)
See here http://www.pgmfi.org/twiki/bin...bHome
The WIKI is down right now for some reason, but you can visit the forums for some interesting reads. http://forum.pgmfi.org/
SingleCamin
14
Mar 7, 2009 10:14 AM
hondateg10
Mar 25, 2007 03:50 PM
egboostin6
Mar 20, 2007 12:28 PM
iH8RICERZ
Oct 24, 2002 09:57 PM
