K20A2 In a DA Integra?
Old Apr 18, 2007 | 12:11 PM
super china china's Avatar
Default K20A2 In a DA Integra?
Is this possible? What all will i be needing to do this swap if possible?
If not possible, same questions for an F20C?
Old Apr 18, 2007 | 12:30 PM
doood's Avatar
been there done that
Default Re: K20A2 In a DA Integra? (super china china)
about $10k
F20C's are rwd. goodluck with that.
Old Apr 18, 2007 | 01:58 PM
Default Re: K20A2 In a DA Integra? (doood)
well i have access to the k20a2 for about 3k but i mean what parts will i need? i oculd use a little more detailed info other than " about 10k"
i know its going to be a lot of work and money. dont worry about that. i just need info.
Old Apr 18, 2007 | 02:17 PM
doood's Avatar
mounts (there dont seem to be any available for DA's from hasport or hybrid so custom)
axles
wiring harness
ecu and kpro
header
fuel system
and all the other little odds and ends. it's going to be really expensive.
Old Apr 19, 2007 | 04:46 AM
Madness's Avatar
Your Answers Are All Around You.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ? &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Apr 19, 2007 | 06:56 AM
mike-y's Avatar
you'll basically need to use the kit meant for 88-91 civics/crx. Check hasport for mounts and other parts you will need.
everything is custom, and it requires drilling, cutting off old mounts, relocating brake lines, possibly some welding, and a lot of money for all the parts you will need to complete it.
check out k20a.org too
Old Apr 19, 2007 | 10:40 AM
Default Re: K20A2 In a DA Integra? (mike-y)
thanks that k20a.org is badass.
Old Apr 19, 2007 | 01:42 PM
brian L.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super china china &raquo;</TD></TR><TR><TD CLASS="quote">thanks that k20a.org is badass.</TD></TR></TABLE>
It's the best spot to learn about K20 and the swaps
RenzoDaPlayboi
May 3, 2007 09:58 AM
sixfiveoh
Nov 8, 2006 09:55 AM
Shaun_
Nov 8, 2006 08:48 AM
fbpem1
Apr 28, 2006 03:03 PM
twogengsr
Jul 5, 2004 01:50 PM
