D16 crank pulley
Old May 28, 2002 | 03:06 PM
Malgerus's Avatar
Default D16 crank pulley
I just had a thought...
My D16Y8 crank pulley weighs a TON. I know that my old D16A6 crank pulley is much much lighter (at least half the weight)... My question is, can I change them over adn use the A6 crank pulley on the Y8? I know that they do not directly bolt on, but can I change what's underneath it to accept the A6 pulley ? (I haven't really taken a look under there yet). The reason I would do this is that we all know that lighter rotational weight = more power and longevity on parts... what do you all think?? Would the timing belt still work on my Y8??
Old May 28, 2002 | 04:11 PM
chasrex's Avatar
Default Re: D16 crank pulley (89_Y_49)
The crank pulleys weigh a ton for a reason, they are a two-piece construction with a harmonic balancer built in. This reduces vibration at high-RPM's saving your oil pump and main bearings. The Y8's have a bad rep with main bearings already so if you want to keep this engine for a while it would be best to leave the crank pulley alone. If you want to remove rotational inertia and mass, first remove it by replacing the flywheel with a light-weight aluminum or chromoly unit. Always respect the work of Honda engineers, they do things for a reason.
$0.02
Charles
Old May 28, 2002 | 04:53 PM
MrTodd's Avatar
Default Re: D16 crank pulley (chasrex)
No, I think that was a 0.01$ writeup.
Old May 28, 2002 | 05:36 PM
Malgerus's Avatar
$0.02
Charles
Ok, that sounds pretty reasonable. I guess I'll just leave well enough alone Thanks for the input.
Old May 28, 2002 | 07:09 PM
raene's Avatar
If that were the case, why would the A6 pulley be so much lighter...? The logic doesn't follow; the same Honda engineers designed the A6, albeit 7-8 years earlier
Old May 28, 2002 | 07:11 PM
Hayasa15's Avatar
Default Re: D16 crank pulley (raene)
is their anyway of making sure that you have the right pulley for your motor?
Old May 28, 2002 | 09:49 PM
chasrex's Avatar
A6 crank pulley is only 2 pounds lighter. The A6 and Z6 blocks have a reputation of being beefier than the Y8. Taking a pound of the flywheel is about the same as taking 3+ pounds off the crank pulley because of larger diameter and rotational inertia of the flywheel. There are more gains to be had by going light on the flywheel. According to SCC, AEBS's Paulus Lee actually goes out of his way to find the heaviest Honda crank pulleys for his race engines. I guess he doesn't like to tear down his race engines more than once a year.
Charles
Old May 29, 2002 | 05:38 AM
88_SC_CRX_Si's Avatar
New User
When the crank pully started seperating on my D16, I tried re-placing it with the lighter pully off an HF. VERY BAD MISTAKE...... The vibration that I picked-up, would rattle the fillings out of your teeth.
Old May 29, 2002 | 07:08 AM
Todd00's Avatar
I said I don't want a title!
All Honda B series and D series motors are internally balanced. The crank pulley does not do any harmonic balancing like you would see on a chevy 350 or something.
Old May 29, 2002 | 07:23 AM
xXx Justin xXx's Avatar
Default Re: D16 crank pulley (Todd00)
besides all that, i know my D16Z6 alt. and dx pulley...the belts groves are different. so i know in my case i would have had to use the old dx alt. as well. this may have been a stupid responce, but it just poped in my head because i remember putting on the alt belt when i put my engine in, i had picked up the old dx belt instead of the D16 belt, and the grooves were diff.
Old May 29, 2002 | 08:03 AM
Steve91's Avatar
Why not just run a Unorthodox Racing pulley and save even more wieght? On a D16a6, the pulley is solid steel, 1 piece. The oil pump is the harmonic balancer on that motor. I've been racing for a year now with a UR pulley and its great.
Old May 29, 2002 | 08:50 AM
Malgerus's Avatar
Default Re: D16 crank pulley (Steve91)
[QUOTE]Why not just run a Unorthodox Racing pulley and save even more wieght? QUOTE]
Because I'm cheap
Maybe that'll be an option later
Old May 29, 2002 | 09:10 AM
chasrex's Avatar
Enough of this nonsense.
http://www.theoldone.com/archive/pul...n_balancer.htm
Charles
Old May 29, 2002 | 10:54 AM
Hayasa15's Avatar
I asked because i cant find my z6 crank pulley and wanted to know how i make sure i put a z6 pulley back on.
Old May 29, 2002 | 01:42 PM
chasrex's Avatar
Default Re: D16 crank pulley (Hayasa15)
My response was not directed at you Hayasa. I guess you can weigh the crank pulley. According to Unorthodox, the Z6 weighs about 4 pounds 3 ounces. If it weighs about that much and everything fits I don't think there will be a problem.
Charles
Old May 30, 2002 | 01:39 AM
Mista Bone's Avatar
D Tranny Guru
you have NO CLUE about the very BAD crank harmonics of a 4 cylinder inline motor.
ESP. a long stroke 1.6L Honda motor.
Yes, I've played with a few SBC's, SBF's, along with Honda Motors.
The B motors with their bigger bore/shorter stroke can get away without the dampener on the crank pulley.
D16's cannot.
Old May 30, 2002 | 04:59 AM
Zer0DazE's Avatar
if you want an unorthodox pulley you can have mine... it will be coming off my car soon.
im me if you want it
Old May 30, 2002 | 09:30 AM
chasrex's Avatar
Default Re: D16 crank pulley (Zer0DazE)
Fill out the Sport Compact survey here if you want a REAL performance lightweight crank pulley w/ silicone damper:
http://www.fluidampr.com/
Charles
alex14
13
Dec 10, 2010 09:28 AM
projectef
Dec 28, 2006 05:25 AM
asefi944
Apr 11, 2005 02:26 PM
no_one_
Dec 19, 2004 10:00 AM
