Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
**** BLOX RACING F/R Camber Kits, Lca, Sway Bars, End Links & MORE !! SALE PRICE*******
Old Apr 18, 2007 | 10:13 AM
project dc2's Avatar
Default ** BLOX RACING F/R Camber Kits, Lca, Sway Bars, & MORE!!** CLEARANCE*
[CENTER]
BLOX Spherical Trailing Arm Bearings
fits 88-91 Civic W/ Disc Brakes, All 92+ Honda Civic,
90-93 Integra ( with washers/spacers), 94+ Integras
Available in Black or Red
220 Shipped
BLOX Camshafts
(Type A, Type, B, Type C, HSL, P-1)
PM for pricing
Blox B/H23 series cam gears 165$ shipped
BLOX Ti Retainers and Dual Valve Springs[/b]
(B-Series)
(D-Series)
(H-Series)
PM or Email me<
BLOXTPS Sensors
(B-Series)
(D-Series)
(H-Series)
37$ Shipped
(K-Series) PM for pricing
BLOX CNC Aluminum B-H series Throttle Bodies
70MM,72 76MM in stock !$230 Shipped
BLOX Adjustable Rear Camber Kit
(1990-01 Integra, 1988-00 Civic)<FONT COLOR="red"> $99.95 Shipped
BLOX Front Camber Kits ** back in Stock**[/b]
(94-01 Integra, 92-00 Civic/Del Sol) – $134.95 Shipped
(96-00 Civic)$139.95 Shipped
BLOXIntake Manifold [/b]
(B18A/B18B/B18C1) -$175.00 Shipped
(B16A/B16B/B18C5) - $175.00 Shipped
BLOXDual Bend Short Shifter
(1994-2001 Integra, 1992-2000 Civic/Del Sol) - All Models
$89.95 Shipped
BLOXSingle Bend Short Shifter
(1990-1993 Integra, 1992-2000 Civic/Del Sol, 1988-1991 CRX) - All Models
$89.95 Shipped
BLOX<Billet Cam Seals - Polish, Red, Blue, Black, AND PURPLE** new color
(Honda B-Series Engine) - All models
$18 Shipped
BLOX Vacuum Manifold - Polish, Red, Blue and Black
(Universal Vacuum Manifold)
<FONT COLOR="red"> $49.95 Shipped</FONT>
BLOX Rear LCA
Applications and colors available:
* 89 -91 CRX/CIVIC/92-95 CIVIC /90-01 Integras (Except type-R)
Colors: Red, Blue, Black, and Silver
* 96-00 Honda Civic
Colors: Blue, Black, Silver, red and gold
$108.00 Shipped
limited quantity on hand !!! 5 sets only !!!!
Blox PURPLE LCA 118$ shipped each
limited quantity on hand !!! 5 sets only !!!! Blox POLISHED LCA 128$ shipped
BLOX Sway Bar:
Sale price: $140 shipped!
<BLOX Non- Adj Rear Sway bar End link Set:
Regular price: $54.95
$40 shipped!
BLOX Spherical Bearing Adj Rear End Link Set
$50 shipped!
BLOX Extended Wheel Studs
(A set of 8) -$40 shipped
(A set of 10) - $50 shipped
(A set of 16) - $65 shipped
(A set of 20) - $80 shipped
BLOX Black Chrome Chromoly Lug nuts
(A Set of 16) -$95shipped
(A Set of 20) - $110shipped
BLOX Anodized Black Aluminum Lug nuts
(A Set of 16) - $80shipped
(A Set of 20) - $95shipped
* Blox Racing Pro MBC ( Manual Boost Controller) kit contains Blox's Pro valve. The new Pro valve is machined out of billet aluminum and stainless steel pieces. The new design of the valve incorporates some great new features not currently available on any other manual boost controller.
* The Blox MBC has a ceramic ball The ceramic ball weighs a fraction of what the stainless steel ***** weighs. This weight difference allows the ceramic ball to act very quickly as it is constantly changing directions during operation. This helps to minimize spiking, particularly when used with applications that produce lower boost.
* the Pro valve to not require the use of a lock nut or any type or allen wrench(s) to be able to adjust your boost. Simply turn the adjustment **** and it stays. Another great feature is the fact that the adjustment **** cannot be lost or come out of the valve. Simply put there is not a potential for over boosting since the adjustment **** cannot vibrate loose and come out.
* The Pro kit also includes: 3 feet of vacuum line, mounting bracket, hardware packet and complete installation instructions all in one kit. This kit has all the installation hardware that is needed for most all turbo installs. Plus, it comes with a mounting clamp to hold the valve.
* Color: Anodized black
75$ shipped within 48 states USA
How to order:
Payment Options:
Paypal---Google Checkout --Money Order/Check/Cashiers Check.
Paypal id: Racerswholesale@gmail.com
GoogleCheckout Id: SPoolindevelopment@gmail.com
call 408.515.4296 for Visa/Mastercard
Local Pick up:
Spoolin/Redzone Performance
43257 Osgood Rd
Fremont, CA 94539
Old Apr 19, 2007 | 07:47 AM
Default Re: **** BLOX RACING F/R Camber Kits, Lca, Sway Bars, End Links & MORE !! SALE PRICE******* (projec
ttt
Old Apr 20, 2007 | 07:15 AM
ttttt
Old Apr 21, 2007 | 06:20 PM
tttttttt
Old Apr 22, 2007 | 05:21 PM
ttt
Old Apr 23, 2007 | 07:59 AM
tt
Old Apr 24, 2007 | 07:58 AM
tt
Old Apr 24, 2007 | 04:02 PM
Bob Dole!'s Avatar
How much for the red lca's for an eg?
Old Apr 24, 2007 | 05:39 PM
100 shipped
Old Apr 24, 2007 | 07:46 PM
mengo_charged's Avatar
Payment sent for red EK Blox lca's!
Old Apr 25, 2007 | 08:09 AM
tttt
Old Apr 25, 2007 | 04:11 PM
civexspeedy's Avatar
is the sway bar u sell for the rear? will it fit a '95 Honda Civic EX? do u include bushings, endlinks, d-brackets, and hardware?
thanks!
Old Apr 25, 2007 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civexspeedy &raquo;</TD></TR><TR><TD CLASS="quote">is the sway bar u sell for the rear? will it fit a '95 Honda Civic EX? do u include bushings, endlinks, d-brackets, and hardware?
thanks!</TD></TR></TABLE>
it includes hardware, bushings but no end links !!! you're also goign to need some 93-94 integra rear LCA's with sway bar bracket provisions because your factory rear LCA does not support a rear sway bar setup. OR buy some blox ones and some nice adjustable rear sway bar end links and it would be a pretty tight setup.
Old Apr 26, 2007 | 07:51 AM
tttt pms replied
Old Apr 30, 2007 | 08:23 AM
ttttt
Old May 1, 2007 | 08:17 AM
ttttt
Old May 2, 2007 | 06:14 AM
Old May 3, 2007 | 05:02 AM
PM'ed you, it's IMPORTANT!!!
Old May 3, 2007 | 09:29 AM
ttttt
Old May 4, 2007 | 09:54 AM
tttt
Old May 7, 2007 | 08:56 AM
ttttt
Old May 8, 2007 | 06:37 AM
ttt
Old May 9, 2007 | 07:13 AM
pms replied
Old May 9, 2007 | 05:56 PM
1158's Avatar
How much for the black LCAs for DC2?
Old May 9, 2007 | 08:16 PM
Default Re: (1158)
100 shipped in stock !
