search not found
i have all four injectors and wiring from 5th gen wiring to firewall wit color yellow/black stripe shorter which wirees go to which ondp harness for 91 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture »</TD></TR><TR><TD CLASS="quote">i have all four injectors and wiring from 5th gen wiring to firewall wit color yellow/black stripe shorter which wirees go to which ondp harness for 91 civic
WHAT??? Honestly you expect us to know from that bad of a post?
I can tell you this, you aren't suppose to swap harnesses, ever, unless you do a FULL harness swap. Reason is, you have issues like the one you are facing right now.
Modify your stock harness, much easier and safer in the long run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture »</TD></TR><TR><TD CLASS="quote">I have all four injectors and an EG engine wire harness. The yellow/black wires is shorter. How do I mate this harness to my stock 91 Civic one?</TD></TR></TABLE>
I believe that is what he was trying to say, altough I still don't understand what he's trying to do. I will agree with ludesrv in that you should modify your stock harness instead of splicing two of them together.
91crxturbob16
Aug 27, 2007 04:43 PM
