Hasport mounts....can I remove my transmission mount?
I have a GSR swap in my hatch. I'm going to be using Hasports EGSTK kit, which replaces my integra mounts. I'm doing this to clean the bay up and replace the worn out mounts.
Now, the question is, can I remove the transmission mount on the passenger side? I think it would look cleaner, and I'm unsure if it is necessary. Since the Hasports are a more heavy duty mount, I would think that it would be able to support this. Some folks in the "shaved engine bay" thread in Apperance have removed this mount.
If not, no big deal, I'll keep it in place.
Thanks in advance.
Modified by tweeter at 9:49 AM 4/18/2007
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TNRspeed »</TD></TR><TR><TD CLASS="quote">my friend has the same set-up and he isnt using his. you are talking about the one that goes under the frame rail? if so then it shouldnt be a problem</TD></TR></TABLE>
Yes, that is the one I'm speaking of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch »</TD></TR><TR><TD CLASS="quote">you cant use the egstk kit</TD></TR></TABLE>
Which one would I use?
I called the retailer I'm getting them from and he asked if my driver side is 3 bolt or 2 bolt. I told him 3 and he said he stocks that kit. I'm assuming, even according to Hasport's website, that I can use this kit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">you need the DCSTK
And if you're talking about the torque mount, I'd leave it on. Less wheelhop
You were correct, picked it up today, put it on, and it feels much better. My old mounts were worn.
Thanks.
</TD></TR></TABLE>You were correct, picked it up today, put it on, and it feels much better. My old mounts were worn.
Thanks.
Nova_Dust
Mar 14, 2008 04:40 PM
