tranies specs used on your B series turbo and how high you rev?
Old Apr 18, 2007 | 08:22 AM
grumpydominican's Avatar
Default tranies specs used on your B series turbo and how high you rev?
I'm running a stock gsr tranny no cuff, spool and a 4.40 final ratio.
I justa want to know in what gear are you guys passing the 1320 with your set up
depending in track condition I see 5th a lot of spins going on.
Old Apr 18, 2007 | 08:41 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: tranies specs used on your B series turbo and how high you rev? (grumpydominican)
last year, stock b16 with g.s. syncros, 24.5's trapping 8800-9000. 4th gear.
this year same trans, except, gsr 4th, and a liberty cuff and 25" tires. we shall see where i am trapping.
Old Apr 18, 2007 | 08:56 AM
nasteboyii's Avatar
Default Re: tranies specs used on your B series turbo and how high you rev? (boostedcivicsir)
Mikey
R u on every post or what
My setup on 225 50 15 BFG on total b16a trans hydro 4.40 final
went 133mph on limiter at 9500
then switched to gsr 4th gear trapping around 9k
hope this helps
(basically radials are about 24.5 inch size slicks)
take it easy
dan
Old Apr 18, 2007 | 09:00 AM
Mr. Badwrench
Default Re: tranies specs used on your B series turbo and how high you rev? (nasteboyii)
no parts, credit hold, nothing to do, and the race car isnt here.
so i have nothing to do. and what are you spying on me? you seem to reply to every post ihave he hee.
Old Apr 18, 2007 | 09:06 AM
Turbo-charged's Avatar
GSR Trans, 24.5 tires, 4th gear trap, 160 mph, rev limiter at 10800.
Old Apr 18, 2007 | 02:46 PM
1FSTHATCH's Avatar
Default Re: tranies specs used on your B series turbo and how high you rev? (Turbo-charged)
LS, 26.0 tires, 4th gear in traps, 143mph, reving around 8800 rpm across the line..
Old Apr 18, 2007 | 06:02 PM
hndarcrb18c1's Avatar
Default Re: tranies specs used on your B series turbo and how high you rev? (1FSTHATCH)
Stock JDM GSR 140 mph traps 4th gear 9100 rpms
10.44@140 M&H 25.0 13"in rim
Old Apr 19, 2007 | 06:53 AM
b18c195's Avatar
Default Re: tranies specs used on your B series turbo and how high you rev? (hndarcrb18c1)
stock gsr trans with lsd
trap 140+ at 8000 rpm (limiter at 9500) 24.5X8.5X15
Old Apr 19, 2007 | 10:43 AM
Default Re: tranies specs used on your B series turbo and how high you rev? (b18c195)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c195 &raquo;</TD></TR><TR><TD CLASS="quote">stock gsr trans with lsd
ok
looks like you are doing something right there!!
what is set up exactly suspention wise I cant get to go under 1.85 60 ft and spinning all the way down the track. any help apriciated
Old Apr 19, 2007 | 11:53 AM
WOPCIVIC's Avatar
GSR trans, 24.5 tire, 149mph, 9700rpm
Old Apr 19, 2007 | 12:18 PM
b18c195's Avatar
what kinda tires r u running slicks? size?
how much power r u making?
I just run tiens full coilovers. no traction bars, no 2 step, no anti lag
I launch at about 8 grand dumping the cluch no preloading either.
if ur spinning all the way down the track lower ur air pressure on ur slicks.. or get bigger slicks...
Old Apr 19, 2007 | 06:59 PM
what kinda tires r u running slicks? yes, 26-8-15
425 with out the bottle and 525 with it
spraying the car on 3 and 4th. on a crx
do you have the front part strap down, tied down? on your car?
what kind of lsd are you running?
I need some help people
I run the car on a tire restricted class here and can go over 26-8.0 on slicks
Old Apr 19, 2007 | 07:19 PM
PremierS372's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndarcrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Stock JDM GSR 140 mph traps 4th gear 9100 rpms
10.44@140 M&H 25.0 13"in rim</TD></TR></TABLE>
I do the same.
Old Apr 20, 2007 | 06:17 AM
b18c195's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grumpydominican &raquo;</TD></TR><TR><TD CLASS="quote">
I run the car on a tire restricted class here and can go over 26-8.0 on slicks</TD></TR></TABLE>
I'm running a quaife lsd
ur slick size is pretty decent.
but now ur car is a lot lighter than mine probably 400+ pounds or more
how much air pressure r u running on slicks?
no I don't have anything tied down... I didn't know what u mean by that thought
Old Apr 20, 2007 | 03:57 PM
some people strap their suspension.
everything is stock on my car the shasfts everything
how about your aligment caster tow camber I need something to get this thing to hoock up
I have 1.8-2degrees neg camber
caster 0.0 and the tow 0-0.5 degree neg
Modified by grumpydominican at 5:44 PM 4/20/2007
RuskeR
Transmission & Drivetrain
10
Jun 6, 2020 10:26 AM
catfishracer4748
Feb 27, 2010 10:20 AM
MrParks
Jan 6, 2007 10:56 AM
Outkast95LS
Dec 30, 2004 08:55 AM
mingbling
Jul 25, 2004 04:47 PM
