Cluster problem in my 94 HB DX...
Old May 28, 2002 | 02:45 PM
OhPhuck's Avatar
Default Cluster problem in my 94 HB DX...
I replaced my 94 DX cluster with one that has a tach. My hatch is a 5speed, but the new cluster was a auto. I thought this wouldnt be a problem cuz i was just gonna just get indiglos or something. Well, I just installed the new cluster, but the tach is acting weird. It likes to sit at 0 RPM alot. When i start my car, its a 0 even though it should be at like 600 or so. Then when I start moving it jumps up, but when i shift, it goes back to 0, then jumps up again. Why is the tach loving the 0 RPM so much?? Anyone else experience this or know what might be wrong? Also, I wanna know will I need new LCAs if I get a ITR sway bar, or can i use the ones that came stock on my 94 DX hatch? Thanks
Old May 28, 2002 | 03:10 PM
civicmark's Avatar
Default Re: Cluster problem in my 94 HB DX... (OhPhuck)
on the tach, i had the same problem with my spedometer, but all i did was tighten all of the screws on the cluster and checked the sensors. basically made sure everything was tight, and that fixed it
good luck
[Modified by civicmark, 12:11 AM 5/29/2002]
Old May 28, 2002 | 03:18 PM
osu s2k's Avatar
Default Re: Cluster problem in my 94 HB DX... (civicmark)
do you have a motor swap
Old May 28, 2002 | 03:32 PM
OhPhuck's Avatar
Default Re: Cluster problem in my 94 HB DX... (osu s2k)
nope, almost EVERYTHING in my car is stock.
Old May 28, 2002 | 03:50 PM
B_CRUZ!'s Avatar
its probably the loose screws in the back or it is a bad cluster. i have a 95 EX one for sale that is a 5 speed. let me know...
Old May 28, 2002 | 11:24 PM
OhPhuck's Avatar
Default Re: Cluster problem in my 94 HB DX... (B_Cruz)
Hmm, if i cant solve this problem, how much do your want for your cluster? I wont know until this weekend tho cuz i dont have time to play around with it til then.
Old May 29, 2002 | 05:53 AM
Jason kiDD's Avatar
I might be interested as well.. Hit me up on the email.. I dont have any cluster at all, only the cx one..
jdjoseph2000@hotmail.com
1SikEagle
Oct 27, 2008 10:14 PM
spikehead221
Feb 28, 2008 11:28 PM
ShadyBAB
Jan 17, 2006 03:47 PM
gondzur
Aug 30, 2004 08:24 PM
mycivicdx
Aug 26, 2003 05:06 PM
