Engine conversion help (Integra Type r)
Old Apr 18, 2007 | 08:15 AM
COLKEOWN's Avatar
Default Engine conversion help (Integra Type r)
YO wot up !
Im putting an Integra type r engine into my 94 civic dx hatch this weekend, is there anyone that can give me a heads up on wot problems i may run into....
ALSO
i have upgraded my brakes all round to 98 civic vti brakes will these stop this beast
Old Apr 18, 2007 | 08:23 AM
2wheelhunter's Avatar
Default Re: Engine conversion help (COLKEOWN)
uhh yeah... anyways to answer your question, make sure that you have all the needed parts such as axles, mounts, shift linkage, ecu, etc.. as for doing the swap itself a couple major problems are the shift linkage roll pin, best bet is to use and air chisel and a punch, next would be the TPS they tend to get in the way so if possible take it off and re-install it after the motor is bolted in... time and patience and use your head and it won't be too bad!
good luck with your "beast"
Old Apr 18, 2007 | 08:35 AM
sauceja's Avatar
You will have to wire vtec from the ecu to the engine bay. You need a rear L-bracket if the motor didn't come with one from a 94-01 teggy or 99-00 si.
Not sure which year or usdm jdm type r's had the different axle sizes.
Otherwise pretty straitforward swap.
Old Apr 18, 2007 | 08:38 AM
COLKEOWN's Avatar
cheers for help, hopefully all goes well
Old Apr 18, 2007 | 09:05 AM
EGhatch87's Avatar
99-00 si rear t-bracket wont work
02TypeSKeys
May 18, 2010 06:18 AM
cman101
Aug 28, 2009 08:14 AM
RWOL
Jan 30, 2006 06:45 PM
jerzeytib
Oct 27, 2003 03:18 PM
Sasha1012
May 5, 2003 08:46 AM
