will gsr 94-00 seats bolt up in an ek? how well do the fit?
wondering how well a set of gsr seats woul fit in an ek hatch?? they fit pretty well in my eg, is the bolt pattern the same in the 96-00 models?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabinger »</TD></TR><TR><TD CLASS="quote">how about the backs?</TD></TR></TABLE>
2dr backrests with 4dr cushions
if u dont swap the inner rails u will have to drill a hole thru ur floor for the inner back screw and if u do that use a bolt at least thats what i did and it works just fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabinger »</TD></TR><TR><TD CLASS="quote">so i need the bottom cushion from a 4dr?</TD></TR></TABLE>
Yes, to minimize the gap from the cushion to the backrest, and the gaps on the sides.
For rear backrest, just removed leather from GSR rear backrest and replaced on EK hatch. Problem came when installing the bottom cushion as mentioned above. About 2inch gaps on both sides (also noticed a slight gap b/t back support and bottom cushion). I regret passing on a free 4dr bottom cushion...
Good Luck
Good Luck
Ya@inlinePRO
Aug 23, 2002 01:55 PM
