Coupe getting wet
Coupe getting wet
Hi, i have a honda Civic 95 coupe 1.6 vtec. My coupe gets wet all the time and it has not wholes anywere its only the floor on the LH (driver's Side) is there any caps that may have fallen off to cause the coupe to get wet like this??? it gets soaked everytime it rains or snows?
Re: Coupe getting wet (vlad.bg)
check the window seals, the door rubber seals along the edge too... thats the only thing i can think of if theres no holes anywhere else.....if ur driving it when its raining do u notice in runoff water from anywhere...check that next time theres rain...good luck
Re: Coupe getting wet (malubawla)
have you checked under the car? your floor boards may be rusted and maybe forming a hole. good luck i had the same problem with a nissan sentra but i sold it.
Re: Coupe getting wet (SpeedoKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing »</TD></TR><TR><TD CLASS="quote">have you checked under the car? your floor boards may be rusted and maybe forming a hole. good luck i had the same problem with a nissan sentra but i sold it.</TD></TR></TABLE>
Dats wat i was thinking.
Coupe getting wet
I dont think its the molding on the door and the windows because its not getting wet from the windows. The side capret thats right by the door is not wet at all its only the floor on the drivers side the bump thats underneath the seat that hold the actual seat isnt wet either its only the carpet right on the floor....anywere higher than just the floor is dry. rust could be forming a whole on the floorboards but i looked not really good cuz i need to get it on a lift to actually see the whole floor boards underneath but i saw the drivers side (which is the one getting wet) and i couldnt see any wholes. theres just a plastic cap??? or something like that but it seemed perfectly in place when i tried taking it out to see if its loose.
have you had the windshield replaced cause it was broken? possibly it was not sealed right?just a thought,i had that problem with an older car.when it pours,it sucks...
* B A N N E D *
if you take the sideskirt off , and if you remove the fenders you will seriosuly see about 3 rubber gromets covering up holes that go into the interior, that i likely to be your source of watter since the watter goes inbetween the fender along the chassis, and down to the ground
take off the splash shield, bumper, fender, and open the door youll see what im talking about, i had to replace those on my project car also
Re: Coupe getting wet (spork motorsports)
you can also be getting water from your firewall. A rubber grommet might be bad of have fallen out. Just something else to check. Also could be your windshield seal.
cstone
01-29-2010 12:20 AM
miatarocket
Other Make Vehicles
11
06-09-2008 09:21 AM
