need a little help
first i want to ask is it possible to use hid's on my stock eg headlight housings...if it is what bulb type of hid's do i buy? i cant seem to find a 9003 hid bulb type
and i also need help installing my tach...is it possible to just connect it to my stock cluster? i have the cluster that already has a tach, but it doesnt seem to work right
any help would be great. thanks everyone
it's "possible", but you're more than likely just going to end up melting the housings, not to mention annoy everyone else on the road.
regarding the tach, do you have any idea what's wrong? you should be able to just connect it to the stock cluster, but if you don't know where the problem is, there's no guarantee it'll fix your troubles.
no. its ugly, because the eg housings are not totally clear it will cast glare everywhere.....search in the cosmetics/appearance forum and there should be several threads that have to do with Hondas+HIDs many recomend against it....
hope that helps
hope that helps
xxghettothixxx
Feb 10, 2008 05:43 PM
