did i get ripped
Depends, if you are low on manual tranny fluid or using the wrong fluid type, or if your cable (cable tranny) or clutch master cylinder /slave cylinder aren't adjusted or functioning properly respectively, the same symptoms can occur. But, if all else is fine, your sincros are worn and you need to replace them. If it comes to that, contact Gearspeed, do a search for them.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazytalk »</TD></TR><TR><TD CLASS="quote">SO THEN I NEED TO CHECK THE FLUID.. I USED GEAR OIL IS THAT FINE???AND HOW DO I ADJUST THE CLUTCH CABLE</TD></TR></TABLE>
gear oil?! mother of God. lol you're supposed to use Honda MTF or 5w-30. Honda MTF works great. DO IT.
whoever told you to use gear oil is an idiot. in the manual it states: regular 10w-30 is acceptable for TEMPORARY usage but honda mtf is recomended. or pretty much any decent MTF including GM synchromesh is a popular choice.
i dont know where people keep getting gear oil from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazytalk »</TD></TR><TR><TD CLASS="quote">i paid 200 and a psp</TD></TR></TABLE>
Well then what did you expect. Good trannies aren't cheap.
I would look into changing or checking your synchros soon though before they start wearing out the dog teeth and other components. Then you are looking at replacing the 3rd gear set which if not mistaken can only be bought as a 3rd/4th gearset combo.
Change the fluid asap though and honda spends buckoo bucks on R&D for all components even fluids so it is the best thing since sliced bread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">WTF why do people keep suggesting GM<---!? syncromesh</TD></TR></TABLE>
Because it works well in Honda transmissions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Because it works well in Honda transmissions. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">Go with Honda MTF. Anything else ain't JDM.</TD></TR></TABLE>
im sure theres another mtf that can be baught in japan... think they have gm's in japan?
