H22A M2B4 LSD Tranny OR H23 Tranny for boost ??
Old Apr 17, 2007 | 11:58 AM
pcguy760's Avatar
Default H22A M2B4 LSD Tranny OR H23 Tranny for boost ??
Well my M2B4 just crapped out on me and I did plan on boosting my H22A by end of the year so while I was searching honda-tech, I found alot of threads saying that the H23A Tranny does not have much difference as the stock H22A Tranny BUT is also better for a boosted motor because of the slightly longer gears...
So now I am wondering if I should just get the H23A Tranny and run it all motor until I boost or fixed the M2B4 LSD Tranny ... BTW, at first, I am only running 8 PSI with Hondata S200b or similar until I can get more $$ to sleeve the block etc.
Also, would a lightened flywheel (10Lbs) make a difference with the H23A Tranny since it has longer gears in my current all motor setup??
Old Apr 17, 2007 | 09:31 PM
pcguy760's Avatar
Default Re: H22A M2B4 LSD Tranny OR H23 Tranny for boost ?? (pcguy760)
Old Apr 18, 2007 | 12:02 AM
jdizzle!
Guest
Posts: n/a
ask dom or brian earl spilner
Old Apr 18, 2007 | 01:06 AM
pcguy760's Avatar
Default Re: H22A M2B4 LSD Tranny OR H23 Tranny for boost ?? (jdizzle!)
I take it you have no clue what teh M2B4 or H23 Tranny is???
nickaj
Nov 6, 2010 10:00 PM
jam89si
Feb 8, 2007 04:29 AM
Sportsaddict_21
Feb 25, 2006 03:17 PM
coil222
Jun 12, 2003 09:29 AM
si93lude
Nov 20, 2001 01:20 AM
