VTEC Soleniod GAsket
Old Apr 17, 2007 | 09:51 AM
twinj's Avatar
Default VTEC Soleniod GAsket
I need to replace my gashket by the vtec solenoid it is a leak coming from right there. Does anyone know what is the proper name for it cause the honda dealership act like they don't know.
Old Apr 17, 2007 | 09:53 AM
Archidictus's Avatar
Unceasing Measure
Default Re: VTEC Soleniod GAsket (twinj)
Spool valve gasket. Sometimes "VTEC spool solenoid gasket," but the former will probably get you what you need .
Go onto http://www.hondaautomotiveparts.com and search for part number 18174. That's the gasket you need. If you can't search for the part number, input your car's specs and search the drop-down menu under "cylinder head".
Old Apr 17, 2007 | 09:57 AM
twinj's Avatar
Thanks Archidictus, Would it be wise to go ahead and replace the cam seal too? Is there anymore seal's or gasket I should replace since i am there?
Old Apr 17, 2007 | 11:39 AM
Unceasing Measure
Default Re: (twinj)
The VTEC solenoid gasket doesn't require you to remove the valve cover, so I'd leave the rest of it alone
Old Apr 17, 2007 | 12:01 PM
Deep V's Avatar
it also comes up as a filter, when i replaced mine, it did.
PS you may also want to order the gasket for the top side of the solenoid while you are at it just to ensure no problems... and remember BE CAREFUL WHEN YOU TORQUE IT! I cracked my old y8's solenoid like -nothing-, GOOD torque wrenchs are your friends!
Old Apr 17, 2007 | 12:53 PM
JDM_teh_WIN!!'s Avatar
Default Re: (Deep V)
There are 2 gaskets. The spool valve gasket and filter ( which goes between the head and the spool valve. And then there is the actual Solenoid gasket which goes between the solenoid and the spool valve.
36172-P08-015 This is the actual Solenoid gasket part #. The spool valve gasket I don't have the part # for.
Old Apr 17, 2007 | 01:26 PM
Bense's Avatar
depends on which vtec solenoid you have
which head?
Old Apr 17, 2007 | 02:59 PM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">depends on which vtec solenoid you have
which head?</TD></TR></TABLE>
This is true, Im assuming it is a B series. If it is a D series that part number most likely wont work for ya.
Old Apr 17, 2007 | 04:19 PM
TNRspeed's Avatar
Default Re: (JDM_teh_WIN!!)
some good info here tying to change mine as well
Old Apr 18, 2007 | 04:09 AM
twinj's Avatar
Yea B16, Do anyone know if it is hard I think I want to go ahead and do it Cause it leaking really bad to the point where the oil runs down the head on the block.
Old Apr 18, 2007 | 04:14 AM
Jay_Sensing's Avatar
It's not hard, there are three 10mm bolts holding it one. You can start and be finished before your first beer is finished.
Old Apr 18, 2007 | 04:22 AM
twinj's Avatar
LOL THANKS
Old Apr 18, 2007 | 06:44 AM
nighttrain33's Avatar
Default Re: (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">It's not hard, there are three 10mm bolts holding it one. You can start and be finished before your first beer is finished.</TD></TR></TABLE>
True that, but...it takes you that long to drink a beer?
And<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">part number 18174 is the gasket you need.</TD></TR></TABLE>
-Shane
drsab2000
Mar 25, 2014 06:05 AM
Viperoholic
Mar 5, 2013 12:44 AM
Elvis1977
Oct 7, 2010 07:00 PM
o0ohaviko0o
Apr 14, 2008 07:09 AM
eh2
Mar 3, 2005 02:04 PM
