Idle issue
I swapped on a d16y8 IM onto my d16a6... all the vacuum lines are in the correct places and one is plugged, because i am not using a dashpot. Anyways, my idle is @ about 2,000 when i start, and will drop to about 1500-1750 in about 3 minutes sitting...but when i drive it, i get no CEL and my idle will bounce sometimes even as fast as 1,000 rpm jump every 2-3 seconds. I dont understand the problem, because i dont think it has air injection becuase its not 99-00. All nuts are on, even the dumb one in the middle/bottom with brand new Hondata Gasket. The idle adjustment screw is all the way closed leading me to think vacuum leak, but i have yet to find one. Any help would be appriciated, new TPS and MAP were put on and my connectors for the two are not switched...thanks
89efDUSTY
12
Apr 18, 2007 07:50 AM
