My Speedo Doesn't work on 94 integra type-r
Old Apr 17, 2007 | 08:43 AM
oh_lee_allen's Avatar
Default My Speedo Doesn't work on 94 integra type-r
Hello I just bought a 94 integra with a type-r swap done to it, and everything works but the speedo, Any help on how to fix this would be great. I've checked the cluster to make sure eveything was hooked up and it was so, Now i'm back there to ask all you how to fix it... I hope you can help.
Old Apr 17, 2007 | 08:48 AM
Utilitarian's Avatar
Default Re: My Speedo Doesn't work on 94 integra type-r (oh_lee_allen)
Did you plug in the VSS?
Old Apr 17, 2007 | 08:50 AM
Default Re: My Speedo Doesn't work on 94 integra type-r (Utilitarian)
I'll be honest with you I don't know much about this car, I've been a old raw muscle car for a long time. So I don't know if it was plugged in, Is it something easy to do?
And thanks for such a fast responce.
Old Apr 17, 2007 | 09:03 AM
RPRacing's Avatar
check your grounds. and your plug
Old Apr 17, 2007 | 09:12 AM
Dave_B's Avatar
Didn't know they made 94 ITR's...
This is what your looking for.
Old Apr 17, 2007 | 09:57 AM
p nut's Avatar
94 ITR.... I think they only made one of those. 94-001
The pic above is from the top of the transmission.
Old Apr 17, 2007 | 10:03 AM
Erik95LS's Avatar
Default Re: (P Nut)
then I must have 95-001
What year is the motor?
Old Apr 17, 2007 | 10:23 AM
grjp1988's Avatar
you know what he meant, a 94 itr swap you ********.. stop being stupid about ****
Old Apr 17, 2007 | 10:45 AM
Default Re: (grjp1988)
Yep Like he said I did the swap, and thanks for all the help I'm gonna try and look and see if that is plugged in in a few hours...
Can't wait to start running this, I'll post some pics when I get home tonight. We'll see how many add-ons you can name that I added
It'll keep all you pro's on top your game
Later
Old Apr 17, 2007 | 10:48 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">you know what he meant, a 94 itr swap you ********.. stop being stupid about ****</TD></TR></TABLE>
Like, totally chill bra...
Did you see that I mocked, then helped?
Pipe down a bit.
Old Apr 17, 2007 | 11:06 AM
Default Re: (Dave_B)
Thanks Dave
I gonna go on my break and check for it. Where at on the transmission is that plug, I just trying to make it easy so I can try and see during break. Thanks again for you help.
Old Apr 17, 2007 | 11:21 AM
Mugen Mike's Avatar
Default Re: (oh_lee_allen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_lee_allen &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Dave
Right on the top - it's the only sensor that plugs into the gearbox.
Old Apr 17, 2007 | 11:29 AM
Mr.OB*GYN_Rhett's Avatar
hahaha
Old Apr 17, 2007 | 11:56 AM
Default Re: (Mugen Mike)
Well I found it, and it was plugged in, I checked to see if it was in all the way and it was. Still didn't work.
So the next is to replace it I would guess. What do you all think?
Old Apr 17, 2007 | 12:30 PM
BDiddy's Avatar
check your grounds and your fuses?
Did the speedo work before you did the swap? The piece may be broken if it came with the swap and its a new cluster.
Old Apr 17, 2007 | 12:38 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Right on the top - it's the only sensor that plugs into the gearbox.</TD></TR></TABLE>
(the only one besides the reverse-engaged switch for backup lights)
Old Apr 17, 2007 | 12:39 PM
Default Re: (BDiddy)
Thanks I'll check the fuses and the grounds.
Old Apr 17, 2007 | 12:47 PM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_lee_allen &raquo;</TD></TR><TR><TD CLASS="quote">Thanks I'll check the fuses and the grounds.</TD></TR></TABLE>
Also check the VSS again, unplug and look at the connectors on both the harness and VSS itself. I just replaced mine because it has corrosion on it. Check and see if you see any green color on any of the 3 prongs.
Other than that, could be a few things.
Old Apr 17, 2007 | 01:27 PM
GO-FIGHT-KILL's Avatar
Oh sorry, I was under the assumption that this was the Type-R Integra forum... Not Type-R swapped car forum. Calm down a bit dude.
Old Apr 17, 2007 | 02:39 PM
vivid 02's Avatar
for whatever reason if you are really low in oil in the transmission your speedo will also not work. since you just did this swap did u refill the tranny?
Old Apr 18, 2007 | 09:30 AM
Default Re: (vivid 02)
Well nothing worked so far, I'll check the Trans again, and then I'm just gonna get a new VSS.
Thanks all for your help!!!
Old Apr 18, 2007 | 09:42 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_lee_allen &raquo;</TD></TR><TR><TD CLASS="quote">Well nothing worked so far, I'll check the Trans again, and then I'm just gonna get a new VSS.
Thanks all for your help!!! </TD></TR></TABLE>
My buddies VSS wasnt working all the sudden on his car and it turned out to be the connector itself, looked a lot like Dave was describing. Spliced in a new connector and it seems to be ok.
&lt;&lt;&lt;did not realize the speedo wouldnt work if the fluid is low??? I thought it was just a gear riding on another gear...
Old Apr 18, 2007 | 09:45 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid 02 &raquo;</TD></TR><TR><TD CLASS="quote">for whatever reason if you are really low in oil in the transmission your speedo will also not work. since you just did this swap did u refill the tranny?</TD></TR></TABLE>
Thats not true.
Old Apr 18, 2007 | 09:56 AM
Erik95LS's Avatar
Default Re: (I love lamp.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I love lamp. &raquo;</TD></TR><TR><TD CLASS="quote">&lt;&lt;&lt;did not realize the speedo wouldnt work if the fluid is low??? I thought it was just a gear riding on another gear...</TD></TR></TABLE>
it is
Old Apr 18, 2007 | 09:57 AM
Mugen Mike's Avatar
Duh! When's the last time you checked your VSS fluid?
