Cruise control problem
Try testing the brake light switch behind the brake pedal before buying one. I wasted money on one and ended up cleaning and bending the contacts inside the CC unit on the steering wheel. Also make sure you check the fuse and have no vacuum hoses loose.
all my lights come on saying that the cruise is working, tap the brake and the light goes off but..... If I let off the throttle my car does not hold speed?
