help! rear differencial on my S2000 damaged...
You can buy parts online from many dealers. Heres one that has pretty good prices.http://hondiscountparts.com/
However, if you have never set up a rear end, I would suggest handing the job over to a mechanic. You need to make sure that the gears mesh properly, and you need the right preload on the end caps. You wouldent want to blow your rear diff again.
