Honda S2000 Honda S2000
Any tricks or anything different when installing......
Old Apr 14, 2007 | 11:40 AM
patricks2000's Avatar
Default Any tricks or anything different when installing......
Any tricks or anything different when installing the tein S tech springs on my 2006 s2000? thanks alot
Old Apr 14, 2007 | 01:13 PM
fbp-em1's Avatar
Default Re: Any tricks or anything different when installing...... (patricks2000)
silly rabbit.. tricks are for kids
just take your time, its not to hard
Old Apr 14, 2007 | 03:09 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Any tricks or anything different when installing...... (fbp-em1)
why diud you go with Stechs.. i would have went with different springs personally
Old Apr 14, 2007 | 04:21 PM
SuzukaBlueAP2's Avatar
Default Re: Any tricks or anything different when installing...... (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">why diud you go with Stechs.. i would have went with different springs personally</TD></TR></TABLE>
now...now....that's not the point.
To the OP...
are you changing shocks, too or just the springs?
Old Apr 15, 2007 | 07:43 AM
slammed_s2k's Avatar
Default Re: Any tricks or anything different when installing...... (SuzukaBlueAP2)
just be patient shouldnt be hard at all.i installed my skunk 2s and didnt take too long
Old Apr 15, 2007 | 04:28 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">
just wanna know.... they arent known to be a good spring
Old Apr 17, 2007 | 08:34 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
oh man you're in for a -- knuckle smashing, wrist bruising, and neighbors hearing you yell swear words, then kicking someone else's dog, and then going back inside-- kinda time. It's kinda tight in there. Dont be like me and be lazy and say "i dont need to unhook the swaybar". You have to take off the UCA for the front suspension, and the swaybar link for the rear to get everything out. Then loosen all your bolts that go to bushings that twist when the suspension compresses so you can get more droop to take out the old set up. Then jack up the control arm with the new springs in ..and retighten the bushing bolts so you dont go thru bushings. Make sure the pigtails on the spring line up perfectly with the nooks in the shock or you wont get the shock back in. lets see..what else...what else...yeah thats really all. Good luck with the bolt in the rear by the gasline, btw. that was soooo rad of honda to do that. Use a slimmer ratchet, short 14mm socket, and a few creative swear words.
Old Apr 17, 2007 | 09:41 PM
Mr. Projekt's Avatar
* B A N N E D *
When taking out the front shocks, remove the 2 bottom 17mm bolts of the knuckle. It helps in getting the front assembly out.
When taking out the rear, have a friend, preferably heavy-set, step on the knuckle to get enough clearance to pull out the rears. Putting a layer of tape on the 14mm socket help keeps you from losing the nuts on the upper mounts upon dis/reassembly.
Removing the anti-sway bar links really, REALLY helps.
KING PIN
Suspension & Brakes
Apr 16, 2008 07:44 PM
superdat1
Nov 2, 2007 06:34 AM
shirazi89
Feb 12, 2007 03:46 PM
aquabob89
Suspension & Brakes
13
Dec 2, 2005 08:31 PM
KingJeff
Jul 25, 2004 12:49 PM
