Civic Dx Turbo?
Old May 28, 2002 | 11:50 AM
Ragezero76's Avatar
Default Civic Dx Turbo?
is there anyway i can turbo my 1.5? i would use a T-25 turbo...any way? could i use parts from civic ex turbo kits? and would it be worth it?
Old May 28, 2002 | 12:12 PM
rodrez.'s Avatar
Default Re: Civic Dx Turbo? (Ragezero76)
You can turbo just about any car. Just be sure you don't boost too much, the DX rods are tiny, and won't take too much stress.
Old May 28, 2002 | 07:31 PM
BDTURBO's Avatar
Words of advice...my friend put a Jackson Racing SuperCharger on his 1.5 DX and he boosted the hell out of it something like 13 PSI and he shoots out the biggest cloud og black smoke....keep the boost small until u upgrade the engine
Old May 28, 2002 | 09:07 PM
VtecDeMoN's Avatar
Have you ever seen DX rods? They're like friggin' toothpicks. If you're looking for longevity out of you engine I would say never do it. Plus you could get so much more out of even a d16z turbo then the measley d15.
Brian
Old May 28, 2002 | 09:51 PM
TheIntegraGuy's Avatar
Default Re: Civic Dx Turbo? (PatrickEwing)
Not worth the time or the $$$
True..and not true...A decent B16 swap can be done good with $1600..Brand new GReddy Turbos are $1300 avg price in so cal for a SOHC...now if you spend that $1300 on other stuff, you can't make as much power as you would with the kit...It's well worth it...and the stock D15 can handle about 8lbs without problems....Making your custom kit using a T25 turbo is a good choice, but it'll require lots of knowledge and time. T25's are really small...so you'll be getting full boost at around 2.5k rpms...GReddy uses a turbo similar to TD04 and is little bigger than a T25...IMO, I think it'll be better going with a GReddy kit than a custom. GReddy is more reliable and you'll be getting all new parts except for the IC and the BOV..Keep in mind that the GReddy's for SOHC's do no come with injectors, however, if you're not planning to boost big numbers, you wont need larger injectors...your stock ones will be able to handle it...Good Luck.
[Modified by J-MiGiRL702, 6:54 AM 5/29/2002]
Old May 29, 2002 | 12:37 AM
B_1_8_hatch's Avatar
Default Re: Civic Dx Turbo? (J-MiGiRL702)
what about a zex kit on a 1.5l? how much of a shot can i use without having any problems with my motor? i don't want to blow
my motor so i'm thinking of just using the 25 shot.
93hb
Old May 29, 2002 | 12:47 AM
D16Z6racing's Avatar
Default Re: Civic Dx Turbo? (93hb)
i've been advised not even to run a bolt on boost pressure...6 or 7 lbs. it was memtioned before, "the rods won't hold up." if you want a singel cam w/ boost, find a d16z6 long bolck ($400-$700), and boost it.
Old May 29, 2002 | 04:16 AM
Mista Bone's Avatar
D Tranny Guru
A 1.5L on ZEX at lowest setting.........
http://www.codyscafe.com/~mrbone/pics/zexboom/
Any questions?
Old May 29, 2002 | 11:21 AM
SOHC_power's Avatar
all this diassapointing news about the dx motor....do you guys think a d16y8 could handle it?
Old May 29, 2002 | 11:43 AM
GokuSSJ4's Avatar
wrXtian
10
Sep 17, 2002 08:09 PM
Ragezero76
May 28, 2002 01:56 PM
fEAR9
May 18, 2002 06:10 AM
No More Civic
May 10, 2002 11:03 PM
