Any boosted 03+ K24 Accords out there??
I just bought an 03 Accord with 32K miles on it and I absolutely LOVE IT!!
For now I am noy going to mod it at all since it is under waranty.
However when the waranty runs out I would like to start doing some mods.
I plan to start with I/H/E but would like to go with a supercharger someday...
I would rather go SC than turbo for my own reasons, and don't plan to too overboard with mods as this is a daily driver and always will be.
So does anyone out there make an SC kits? Anyone using one??
I have searched around but haven't seen anything...
I've turbo'd my car, and I have a custom kpro harness made by a guy in Seattle as well. Wasn't cheap, but I did it with good parts so it works great. Just got the car back last wednesday and it runs great, only on 3psi now so I can get used to the clutch and turbo, retuning it next saturday. Although if you do turbo you should look into an lsd, even at 3psi in first gear if I get on it at all I instantly loose traction (even with summer performance tires).
This car is my daily driver, and always will be, hence why I do not plan on building the engine or taking it above a 8psi. One of my friends with a 7th gen sedan and I'm sure others are waiting for the new redshift supercharger kit that runs at 5-6 psi, and is a bit less expensive.
I/H/E and a set of pulleys springs and stuff like that is fine, but when all of that is said and done, you've spent almost as much as you would on a turbo, so think wisely before you start making decisions. FYI the kpro and harness is $1300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic disobedience »</TD></TR><TR><TD CLASS="quote"> this is a daily driver and always will be.
...</TD></TR></TABLE>
How is nitrous an option for that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 »</TD></TR><TR><TD CLASS="quote">How is nitrous an option for that? </TD></TR></TABLE>
Exactly!!
Honestly the reason I would rather stay SC rather than turbo is less clutter, and ancillary requirements...
No oil lines, no drilling the pan, plus I dont like the idea of having a turbo that close to the firewall... SC is a little simpler, and more practical for a DD... no wastegate/echaust issues either...
An SC is more bolt on and go... I know I am over simplifying it. but thats the way I feel...
It will be a couple years before I get serious about this stuff anyway, since I have over 18 months of waranty left.
LSD id also a good point. I will likely do a nice clutch setup while I'm in the area too...
Exactly!!
i would go with a custom turbo set up the power gains are well worth it daily driven or not, and if you have a good engine mangement then you shouldn't have to worry about anything, i ran 10psi daily on my h22accord and raced on the weekends when i could @ 15psi,
