Rear stand question
Old Apr 16, 2007 | 08:48 PM
Muffler Bearing's Avatar
Default Rear stand question
Alright I'm trying to get things sorted up and all that for my cafe project this summer and my question is this. Should I get a plain old regular type rearstand or should I get a spooled one?? Advantages, disadvantages, all that stuff. Thanks guys.
Old Apr 16, 2007 | 08:52 PM
marmaladedad's Avatar
You can't use a spooled rear stand if your bike doesn't have spools.
Pit Bull sells a rear stand that can switch to spool or pads, so you can use either.
Old Apr 16, 2007 | 09:05 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (marmaladeboy)
if it doesn't have spools, just get the other type that lifts from the bottom of your swing arm.
Old Apr 16, 2007 | 10:04 PM
ngng's Avatar
you can get a spool kit and tap your swingarm..then get a spoold stand....i like spooled stands over the swingarm stands
Old Apr 17, 2007 | 05:39 AM
MSchu's Avatar
My Name is Nobody
Default Re: Rear stand question (Muffler Bearing)
either the spool or L bracket works fine...
Old Apr 17, 2007 | 06:25 AM
backlash's Avatar
If you can use spools I would use those. Plus if you have spools, they act like mini sliders for your swingarm in case you happen to go down.
Old Apr 18, 2007 | 11:28 AM
Ok so I guess my main question is, is it worth it to drill spools into my swingarm or will a regular one work just as well??
Old Apr 18, 2007 | 11:38 AM
MSchu's Avatar
My Name is Nobody
Default Re: (Muffler Bearing)
I personally don't like drilling holes in my swing arm. if you use a nutsert or like item you will be okay I am sure, but usually spooled arms are braced around the hole in some small fashion, or they are installed at the dropout where the real meat is at. This is not because the arm will crack when on a stand, but because it will crack at the hole when not on the stand... when it is in use. the holes acts like a starting/weak point for a crack to begin. L brackets work just fine, spools are trick, you make the call
Old Apr 18, 2007 | 02:42 PM
I'd rather be functional than trick y0. Thanks Schu.
Old Apr 18, 2007 | 02:51 PM
On a side note, I had spool-adapters (Pit Bull sells these) welded onto my swingarm so I could use the spool type stand.
Old Apr 18, 2007 | 03:23 PM
How's that workin out for ya??? How much did the welding cost?? I'd imagine not much.
Old Apr 18, 2007 | 03:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muffler Bearing &raquo;</TD></TR><TR><TD CLASS="quote">How's that workin out for ya??? How much did the welding cost?? I'd imagine not much.</TD></TR></TABLE>
It worked great from the time it was welded on to the time I sold the bike. One thing to note is that most welders would not want to do this unless the swingarm was off the bike, or you could flip the bike upside down. The guy I took it to leaned the bike waaaaay over to weld on the adapters.
I don't remember the cost of welding because I had the welder do other stuff to my trailer, but somewhere in the neighborhood of $10 (probably because I had the other stuff done too).
Be sure to check if you need the steel or alyooominimum adapters.
Old Apr 18, 2007 | 03:47 PM
ngng's Avatar
Default Re: Rear stand question (backlash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">If you can use spools I would use those. Plus if you have spools, they act like mini sliders for your swingarm in case you happen to go down. </TD></TR></TABLE>
you mean, WHEN you go down
Old Apr 18, 2007 | 07:23 PM
backlash's Avatar
Default Re: Rear stand question (ngng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngng &raquo;</TD></TR><TR><TD CLASS="quote">
you mean, WHEN you go down </TD></TR></TABLE>
Already been there, not fun, and ya, the swingarm spool/slider worked. No damage to the swinger.
Old Apr 18, 2007 | 08:47 PM
Wicked, thanks so much guys. I think I'll end up getting a standard one just to avoid the hassle and what not. Thanks for all the advice though, you continue to rock my socks.
LSintegra
Honda Motorcycles
Apr 24, 2008 09:39 AM
AllmotorEH2
Jan 8, 2006 09:43 PM
oscar_lopez03
Jan 7, 2005 10:46 PM
dragsol
Mar 24, 2004 06:53 AM
RustyRex
May 10, 2003 06:09 PM
