Fog lights.....
okay, i seracrhed for aobut an hour and came up blank... i want to re wire my CB7 fog lights w/ the factory button so they come on WHENEVER i push the button, not jsut when low beams are on. i want them to be able to be on w/ no lights, low beams and high beams(even tho its supposed to be ilegal
) any insight would help!
are you askin how to wire them up with thier own button? If so all you got to do is ground the - to the frame and the + of both lights to the plug on the back of the button and run one wire from the batt to the other plug on the button
didnt he just tell u how?
positives to the switch (2)
negatives to a ground (2)
power from the battery to the switch (1) = ur 5 wires....
i dont get whatmore ur asking...
Heres 2 links to give you a hand if you are still having trouble:
http://www.cb7tuner.com/vbb/showthread.php?t=46735
Hope that clears it up more for you. Aight, laters.
-1TSXer-
Jan 15, 2005 12:16 PM
