every one else has one so why not me aarontrini85's build thread
Old Apr 16, 2007 | 08:03 PM
aarontrini85's Avatar
Default every one else has one so why not me aarontrini85's build thread
i didnt start taking pics till sunday and most the work was done friday saterday so this first part isnt realy durring the work its more so showing stuff installed.
ok i picked up a 91 crx si in feb. and it was supposed to be a good running car with a obd1 conversion and a d16y8 other then that stock and ready to be a daily driver while a built a motor.
well as you can guess it didnt last the obd0-obd1 harness was wired wrong so i went through and fixed that. then the car seemed to run fine.
about 2 days later i was driving and the headgasket blew. i never noticed the coolant temp gauge wasnt working . the thermostat housing had a rag wedged under it to soak up the coolant that was dripping .
so i went and did arp headstuds a new headgasket and a skunk 2 cam gear just for the hell of it.
i got it running right but since the car had some kind of ghetto wire tuck the harness had a **** load of bad connections from when i took off the harness and put it back in.
at this point in time i decided it was time to sell the D and switch it back to non vtec and work my way up again rather then trying to fix a headache like this.
This is where the build starts but dont think the bad luck ends here lol.
ok first things first was why not fix up the **** bushings on the front end
so one went prothane lca bushings, D bracket bushings, and endlinks.
the uca's will probly be replaced all together once i find a set that doesnt suck.
after that i decided that rather then a d16a6 i would just go with a simple ls motor. so while i hunted that down i picked up a set of hasport mounts and installed them
then i decied to pull off the ghetto exhaust the kid i picked the car up from had installed
then i was going to throw on my blox lca's
and keep my tokico blues and intrax springs.
but looking around the garage i thought why not put my k sports coilovers to use finaly so on went the k sports and these lca's
oem ftw
then saterday night i took a trip to clintonville WI to pick up a motor a not so nice looking b18b1 but i thought looks cant be every thing it will probly work so why not its cheap only $250
the next moring i took a trip to chicago to pick up some stuff for a buddy from jdm jack and he just so happend to have a 1st gen avid tracion bar at a bomb *** deal so i had to pick that up
to bad i had just spent about a hour putting in prothane bushings in my radius arms lol
either way that was the end of this weekend then came today
i was going to install the traction bar but had to pull off a motor mount from the b18 first
so i went and removed the valve cover to get the timing belt cover off and noticed one cam was spining free. i thought hmmm thats not right so i pulled out the cams and looked around
notice any thing missing ??
two rockers were mia
oh wait i found them
wedged under a spring it was a bitch to pry them out with a screw driver
heres the mark the rocker made when it flew out and hit the side of the head
this was pissing me off a little especialy when i noticed the valves were staying down when the rockers werent there. in my head that only meens one thing. crushed valves
i was able to locate a head for $75 from a friend so i know it will work but i think its time to build so its time to hunt down parts
Old Apr 16, 2007 | 08:18 PM
Markland Photo's Avatar
gl with it
Old Apr 16, 2007 | 08:43 PM
RCautoworks's Avatar
Default Re: (bulletspastsunset)
Good luck, hey those are my mounts. See you tomorrow .
Old Apr 16, 2007 | 08:46 PM
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Good luck, hey those are my mounts. See you tomorrow . </TD></TR></TABLE>
man that little wink looks gay put it on the other side of that period
like this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Good luck, hey those are my mounts . See you tomorrow . </TD></TR></TABLE>
but thanks
Old Apr 22, 2007 | 06:31 PM
Default Re: (aarontrini85)
ok couldnt get much done this weekend i just cleaned up the battery relocation and decied i dont want a cd player in this car so i hit up the junkyard and found this
other then that nothing but fixing some broken bolts and oh yeah ordered up a b16a1 swap to bad no one has the damn lsd trans in stock
should be here soon
Old Apr 22, 2007 | 06:39 PM
D C 5's Avatar
good luck with the build, and nice avatar
Old Apr 22, 2007 | 06:46 PM
simonsays's Avatar
New User
good luck, looks like you're off to a good start
Old Apr 22, 2007 | 07:00 PM
B18CivicEH2's Avatar
Default Re: (simonsays)
nice....now, take the head and tranny off the b16 and make an LS VTEC with your LS Block.... it'll be waaaay better then the 1.6
good luck...imma be following this build
Old Apr 22, 2007 | 07:02 PM
Default Re: (B18CivicEH2)
trust me its one of the plans but i want to get it running on the b16 then boost that bitch for this year and in the winter start on the ls vtec probly stroked out a little if the cash is flowing then as good as it is now
Old Apr 22, 2007 | 07:26 PM
Bulli Kid's Avatar
you should have taken the engine back to that guy nice build for now lol
Old Apr 22, 2007 | 07:30 PM
Default Re: (Bulli Kid)
i was having trouble finding a ls motor localy that would "run" so i drove about 4 hours for this pos then 4 back and when i checked it out i was pissed becouse i should have just hit up a junkyard and taken my luck but what ever i learned my lesson
Old Apr 22, 2007 | 07:34 PM
waddy41's Avatar
so far so good
Old Apr 23, 2007 | 07:09 PM
Default Re: (waddy41)
pulled the shitty ef hatch carpet out of the crx and preped the floor and started painting it im doing half flat black the other gloss black then im going to see what i like more and do the whole thing like that
man i feel dizzy as hell lol dont paint with no ventalation and the go run 2 miles immediatly afterwards lol
ill post pics tomorrow so i can get some opinions on flat black or gloss black
Old Apr 24, 2007 | 04:38 AM
tai....'s Avatar
good luck on the build
Old Apr 24, 2007 | 04:45 AM
Phil DeVtec's Avatar
Default Re: (tai....)
good luck...keep us updated.
Old Apr 24, 2007 | 02:31 PM
89efDUSTY's Avatar
Default Re: (Phil DeVtec)
nice...
Old Apr 24, 2007 | 02:55 PM
Default Re: (89efDUSTY)
damn just got off the phone with jdm source it will be almost 2 weeks before i see my motor and im out of cash untill next payday what to do thats under $50 any suggestions?
Old Apr 24, 2007 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">damn just got off the phone with jdm source it will be almost 2 weeks before i see my motor and im out of cash untill next payday what to do thats under $50 any suggestions?</TD></TR></TABLE>
Put a down payment on my header
Old Apr 24, 2007 | 03:27 PM
what about the price of gas
if i still have it when my ecu is done i will
Old Apr 24, 2007 | 04:07 PM
alex_s817's Avatar
looking good, i need your kind of cashflow lol
Old Apr 24, 2007 | 04:22 PM
Jtran's Avatar
Default Re: every one else has one so why not me aarontrini85's build thread (aarontrini85)
Old Apr 24, 2007 | 04:25 PM
Default Re: (alex_s817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">looking good, i need your kind of cashflow lol</TD></TR></TABLE>
dude its not that great lol im a carpenter/electrican and non union at that + i do side work on cars
i just finaly got out of my carpayment thats the only reason i feel not to broke
but thanks guys ill have some pics up today of the painted floor so i can get some opinions
Old Apr 24, 2007 | 04:26 PM
but thanks guys ill have some pics up today of the painted floor so i can get some opinions</TD></TR></TABLE>
Probably slangging drugs, like those young teenage punks
Old Apr 24, 2007 | 04:32 PM
Shadowz7429's Avatar
good work
Old Apr 24, 2007 | 04:45 PM
Probably slangging drugs, like those young teenage punks </TD></TR></TABLE>
not a bad idea then i can get a baller *** welder like yours
