Car wants to stall when coming to a stop or after revving
Old Apr 16, 2007 | 07:44 PM
syler's Avatar
Default Car wants to stall when coming to a stop or after revving
Hi, I found a thread just like this, but I could not reply, it says "invalid post", twas dated 2003.
https://honda-tech.com/zerothread?id=661468
Anyway, just like his problem, when I rev the engine, and let go, the engine would like to stall but its just like catching its breath to normal rpm. I cleaned the IACV, but did not fixed it. could it really be a vaccum leak?
another big problem, if this will not be fixed, I think my A/C motor will break down also, because, when the engine would want to stall, the A/C would shut off automatically(and this is not good). Can anyone help me out?
by the way, my engine is d16z6
Modified by syler at 9:38 PM 4/16/2007
Old Apr 16, 2007 | 07:52 PM
Mr.EM1_EK's Avatar
Default Re: Car wants to stall when coming to a stop or after revving (syler)
try doing a tune up and do check for a vacuum leak. its a good place to start. not sure about the ac though i would say get the first problem fixed the take a look at that.
Old Apr 16, 2007 | 08:39 PM
syler's Avatar
Default Re: Car wants to stall when coming to a stop or after revving (Mr.EM1_EK)
had my engine tuned up already, after a week, this is where it started. Does someone have a picture or a diagram for the vacuums to be checked? d16z6 engine...
Old Apr 16, 2007 | 08:46 PM
CE1's Avatar
CE1
i had one do that right before i spun a bearing
Old Apr 16, 2007 | 09:04 PM
theqballer's Avatar
Default Re: Car wants to stall when coming to a stop or after revving (nonvtecek9)
In in the same spot. Cleaned TB, Intake, New plugs wires, Dizzy is fine, and no apparent vacuum leak. Everyone I know points at the IACV. I've got a B16A2.
Old Apr 18, 2007 | 07:48 PM
syler's Avatar
Old Apr 18, 2007 | 07:52 PM
syler's Avatar
Default Re: Car wants to stall when coming to a stop or after revving (theqballer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theqballer &raquo;</TD></TR><TR><TD CLASS="quote">In in the same spot. Cleaned TB, Intake, New plugs wires, Dizzy is fine, and no apparent vacuum leak. Everyone I know points at the IACV. I've got a B16A2. </TD></TR></TABLE>
Where can you find the vacuum locations?
Old Apr 22, 2007 | 06:43 PM
syler's Avatar
im back, and i finally clean my fitv and iacv and followed all the suggestions here, but still, the choking thing is still on my engine. oh my, i dont know whats next.
Old Apr 22, 2007 | 07:37 PM
NHB's Avatar
NHB
Default Re: (syler)
When I had these symptoms w/ my D16z6, and all the T-body/coolant stuff was squared away, it came down to valves. Check the valve lash if they are all way out of spec range it can cause this sort of thing. Mine would almost stall out when rolling up to a stop sign, valves were all set WAY too tight. I remember one was like .013" when it should be like .020" or something. Good luck.
Old Apr 22, 2007 | 07:39 PM
syler's Avatar
what do you mean by the valves?
Old Apr 22, 2007 | 08:03 PM
NHB's Avatar
NHB
Default Re: (syler)
By valves I mean the intake and exhaust valves--under the valve cover. If you search around the net or grab a Chiltons/Haynes manual, there is a procedure to re-set the lash on each intake and exhaust valve using feeler gauges. Look on one of the stickers underneath the hood and you will find the stock ranges for your particular motor.
You'll need a 12mm wrench, flathead screwdriver and tools to hack the car and rotate the crank by hand. Make sure to re-check each valve after you adjust it because when you tighten the locknut it will sometimes change your lash even if you hold the screwdriver really steady. They make a handy special tool for this but I was always too lazy/cheap to buy one.
If you are confused, take a look at this to get you started.
http://www.c-speedracing.com/h...t.php
Don't take it word for word--this applies to B-series. The idea is the same though. There should be a thread with step by step for z6 somewhere on this forum or another.
Old Apr 22, 2007 | 08:50 PM
syler's Avatar
thanks man, actually the day before yesterday, i took the car to a mechanic and he had this feeler gauges and opened the valve cover and adjusted the valves or whatever you call them. I keep asking why do you need to do that, and he is not talking, maybe he did not want me to know and do it on my own. damm mechanic, does not even know what he is doing for he cannot pin point the problem with my engine. il try to look for another mechanic if I cannot solve this on my own. but thanks for the link man, il still keep this thread up for updates.
Old Apr 22, 2007 | 09:10 PM
92ehatch's Avatar
Default Re: (syler)
im having the exact same problem with my d16z6
i havent pin pointed it yet either
thread here
https://honda-tech.com/zerothread?id=1935415
nothing ive done has helped but it may help you.
(mine has some aftermarket stuff on it tho)
WojtekG
Sep 13, 2018 07:15 AM
tnt_107
May 7, 2009 07:57 PM
lpicken
Aug 20, 2008 08:31 AM
plaidrocks
Jul 5, 2005 09:45 PM
